Results 1 to 10 of 10
Thread: shed some light on equipment choices please?
    Oct 2015
    Maryland
    4
    Question shed some light on equipment choices please?
    Hi there!
    This is my first post but I've been reading here for about the past month trying to learn all that I can to get a lovely pool in the ground at our house - rectangle 18x36 gunite. It definitely isn't just a matter of digging a hole, filling it with water and jumping in.
    This is all new to me so please excuse me if I'm missing something obvious. I'm really trying to do my due diligence and have gotten down to the following list of equipment (glad I avoided the Nature 2 Fusion Soft thanks to this forum):
    Jandy aqua purr
    Jandy phpm pump 1.5 hp
    Jandy de filter v 48
    Aqua cal 155 a Heat Pump
    Polaris Tr 35 p
    How does this all look to you all? Any better choices or am I missing an important thing? Any options/help are really appreciated. Thank you! I'm glad I found this site. It has been so helpful!
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Re: shed some light on equipment choices please?
    Welcome
    What depths are you thinking?
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    May 2015
    Fullerton, CA
    635
    I would go with the DE60
    33x19, 3'4"-5'6", 7ft spa, baja reef, 14'x9', 18" deep, 10,668 Gal. Quartzite coping, Stonescape Tropics Blue mini-pebble, abalone & glass beads. Jandy Equip.(JXi heater, 2.7HPVS pump, PLC1400 SWG, CV580 filter, Aqualink, LEDs)
    TF-100, Doheny Discovery robot.
    Oct 2015
    Maryland
    4
    Thanks. We're thinking depths of 3.5-6'
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Welcome to TFP!
    Be sure to get the 2 speed version of the pump. Running it on low will be plenty of water flow for normal filtration, etc. 2 speed pumps generally move half the water using a quarter of the electricity.
    Oct 2015
    Maryland
    4
    Appreciate it. Thanks!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    agree with going for 2 speed pump at a minimum.
    Get as big of a filter as you can afford. When it comes to filters, the bigger they are the better. less time between cleanings, and the bigger the filter, the lower the pressure in the filter will be, which is a good thing.
    Divin Dave,
    Oct 2015
    Maryland
    4
    Okay. I switched to the DE60 for no additional cost and a variable speed pump - by Jandy - for an extra 500 (after an electric company rebate).
    I wonder if heat pumps come in different speeds.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Don't forget to add a surge protector if you are going to go with a VS pump. They have electronics in them that don't like spikes.
    May 2015
    Fullerton, CA
    635
    There is a new Jandy, 2.7 hp VS pump, I would look at that one, we got it for our build.
