Thread: Non-Chlorine Oxidizing Shock for Spa
    Sep 2015
    OK
    5
    The precise product am using is OXY-SPA from Spa-Depot, Non-Chlorine Oxidizing Shock; 42.8% Potassium Peroxymonosulfate, 57.2% Inert Ingredients, 4.3% Active Oxygen.
    It is my understanding this product is not a sanitizer and therefore should not raise my free chlorine?
    Can you help me understand why my total chlorine jumped 5ppm after adding this product and running pumps for 20-min.
    I am confused that this is increasing my combined chlorine rather than decreasing.
    Thank you,
    LakeLixard
    H2X 19' Trainer Deep SwimSpa, Model 1270. ECO PUR water filter system. 231" X 94" X 60". SwimSpa buried 32" deep with decking/patio built around unit. Spa side capacity = 225 gallons, Swim side capacity = 2045 for a total capacity of 2270 gallons. Ozone system, 4 pumps, 48 jets, LED lights, Aquavibe sound system w/sub woofer. T-100 TFTestKit.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,770
    Re: Non-Chlorine Oxidizing Shock for Spa
    Hi there. I think its just causing false readings...the MPS in that product will cause a false reading on your cc read, I am given to believe.
    I just use beach/chlorine to oxidize after very soak...7 ppm per person per hour is the recommended rate.
    Some prefer MPS...your call...just don't believe te cc part of your tests if you continue to use
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Mar 2007
    San Rafael, CA USA
    12,082
    If you have a FAS-DPD chlorine test like the ones we recommend (the TFTestkits TF-100 or the Taylor K-2006), then you can get the Taylor K-2042 to distinguish between MPS and real CC.
