Thread: Hot Tub Cover Radius
    Sep 2015
    Minneapolis
    1
    I'm looking to buy a new cover for a downeast windsor hot tub. I found a cover on craigslist that is the same size (94" x 94") I need, but has square corners. I need a cover with 4" corner radius.
    The hot tub I have is for a house I'm renting, so I'm trying to cheap out on a used cover, since I may only use it for a year. Landlords won't help with payment.
    How big of a difference will the square corners make in keeping heat and other factors?
    Thanks.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: Hot Tub Cover Radius
    I think it will be fine and have no impact. Should seal just fine.
