Results 1 to 8 of 8
Thread: My Pool is slowly rusting away
    Aug 2015
    Hawaii
    9
    Unhappy My Pool is slowly rusting away
    Please help anyone, my above ground pool is slowly rusting away.. Everytime I get in I look and more rust has acumulated..I know it's from the salt water, I rinse after using it, I even tried spraying rust oleums Never wet, didn't help....Any suggestions before my pool falls down! It's only been up for 5 month.
    I have a Coleman 16X48 above ground pool with a saltwater system and a Krystal clear 16in (410 mm) intex sand filter pump.
    Aug 2015
    Hawaii
    9
    Re: My Pool is slowly rusting away
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    That's certainly unfortunate. The only way to try to stop or slow it is to grind away all the rust, then paint with a few coats of paint suited for painting bare metal. I would take the pool down completely then grind and/or sandblast to clean metal and repaint.
    Isolated Spa - 345 Gallons
    30,421
    Maybe not worth it to try and save. I don't mean to sound snobby but that must be a pretty clunky metal and finish to start rusting so early.
    I also am not so sure much of that can be contributed to salt. It looks like the finish is just breaking down.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,103
    Moving this to a PM
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,609
    Sand bad areas and use Spray Galv on it.
    Aug 2015
    Hawaii
    9
    I really don't want to take the pool down If I don't have to, I will try your suggestion.
    Thankyou
    Aug 2015
    Maine
    45
    Scrape off the loose paint and apply the POR15 or similar system. Sadly, I think this would happen regardless of the salt system.
