Thread: Aqua Logic PS-8 Control - clock problems
    Oct 2015
    Kissimmee/FL
    1
    I'm having this same problem with my 2nd board in 10 years. The 1st board had "no cell power" and I didn't throw it away. Glad I didn't because today I found the video about soldering and I brought it back to life! YAY! Now I need a similar fix for my 2nd board which has the problem of losing time. I can set it correct on Thurs and when I return home Monday afternoon, it thinks it is Sunday early AM. Looked at the solder connections and all look pretty good (I work in electronics and have soldered for the last 30 years). Anyone have a suggestion?
    Sep 2013
    Charleston, SC
    540
    Re: Aqua Logic PS-8 Control - clock problems
    5900 G Fiberglass IG pool (circa 1990), SWG Hayward Aqua Rite GoldLine (2013), IntelliFlo Variable Speed Pump (2013), Hayward Pro Sand Filter (circa 1990), Well water (no iron or other metals fortunately), test with Taylor K2006C, Charleston, SC
    mas985's Avatar
    Pleasanton, CA
    11,741
    I have heard of only one instance of this happening but no fixes to date for this one. I would check the clock circuit which is in the upper left corner of the board. There are crystals located in the area (X1 & X2) which will help you find the area. However, my suspicion is that the clock chip has gone bad which may be difficult to diagnose and replace (surface soldered) but if you have a scope, you could possibly check the clock outputs to make sure they are running.
    Mark
