Results 1 to 8 of 8
Thread: T Cell 15 clean after 93 days
    Jun 2014
    Los Angeles, CA
    104
    I started up my T Cell 15 around July 20, 2015. Today I got an alarm to "Clean T Cell Chlorinator". This is my first pool with a SWG. Is that normal to have to clean it after 3 months? I have played around with settings on it, at one point had it at 65%, then reduced to 55% and just last weekend lowered it to 50% to keep things in check. I think 50% is going to be the right number to keep the FC and salt levels correct. Pump runs 2 hours on high and 7 hours on low per day.
    TIA for any advice
    -Shotcrete Pool. Pebble Sheen. Tile by Dal Tile CW27 Winter Blues. Pool dimensions 45x19 24,360 gallons. Spa dimensions 7x7 825 gallons. -Hayward Equipment: OmniLogic, Main filter pump Ecostar SP3400VSP, Spa pump Ecostar SP3400VSP, Filter 700sq ft Cartridge Filter HCF7030C, T-Cell 15 SWG, GVA 24 valve actuators, Universal ColorLogic 12v LED lights, H500FDN Natural Gas 500,000 BTU heater, TF100 test kit.
    Re: T Cell 15 clean after 93 days
    It's usually just a reminder to check the cell for scale. Check the cell. Clean if necessary and then clear the check cell notice.
    Support the site
    JoyfulNoise's Avatar
    May 2015
    13,177
    Can you provide water test results? Cleaning a cell is usually based on calcium scale build up and so it is important to keep your pool water's CSI balanced and slightly negative to reduce the scaling tendency that can occur inside the cell.
    Matt
    Jun 2014
    Los Angeles, CA
    104
    JAMES W - would you say it's normal for the notice to go on after 90 days? Do we know what parameter causes that notice go on? Is it based on days, number of hours it has run? voltage or amperage?
    JoyfulNoise - please remind me what CSI stands for. What water test results are you looking for?
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    Put all your test results in Pool Math and it will calculate CSI. It is displayed near the bottom of the chart. CSI stands for Calsite Saturation Index. CH tells you how much calcium is in the water, CSI tells you if it will stay in the water or precipitate out as scale. Or if too low, if the water will dissolve the calcium right out of the pools plaster.
    chiefwej
    Jul 2015
    Western NC
    115
    It's based on the number of hours it's been generating.
    Disconnect the cell from electricity and plumbing, then look into it from both ends. If it looks clean, it's okay - reset the timer and forget about it.
    23,000 gallons IG gunite, pebble (I think)
    Hayward SP2610X15 1.5 HP Pump, Hayward sand filter
    Mineral Springs SWCG (it's actually Hayward/Goldline), Hayward Goldline T-CELL-15
    Polaris pool cleaner (with booster pump)
    TF-100, SpeedStir, K-1766 Taylor Salt Test, Lamotte Borate test strips
    Jul 2014
    Hope Mills, NC
    567
    My check cell light comes on every 90 days. After the first 3 or 4 times taking it apart to check, I just reset it. I have never had any build-up or scaling. Just good water I suppose.
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Agreed, my SWG cell has not needed cleaning in over 3 years.
    Here is a an article in Pool School about CSI, Langelier and Calcite Saturation Indices (LSI and CSI)
