Thread: Above ground spa leak
    Jun 2015
    Van Nuys, CA
    42
    Hello there,
    Just finished a new above ground spa addition. Successfully passed plumbing pressure test. Tested the jets 2nd time and noticed a leak (see the picture). It leaks when the jets are on. Would appreciate any advice. Is this fixable? Thank you in advance.
    15K Kidney shape plaster gunite pool, 1.5HP Pentair Whisperflo WFE-6, DE 4820 filter, Hayward 400K BTU NG heater, 9 x 7.5 Raised Spa, 7 Waterway Jets _ One 3 main fold jet by Waterway Plastics (total 9 jets), Spa-Pentair 2HP Whisperflo WFE-8 jet pump, 12 V Hayward Universal Core Logic Pool Light for Spa, Intermatic Sub Panel.
    Jun 2015
    Van Nuys, CA
    42
    Re: Above ground spa leak
    Update: Epoxy putty fixed the small dipping from a coupling inside the concrete.
