Thread: Water seeks it's own level
    ned8377's Avatar
    Apr 2015
    Wake Forest, NC
    242
    I have a slide that is about 10 ft tall. If I cut the pump off, will the water in the slide fall to the level of the pool water at some point? I am asking this because I would like to be able to drain the slide and then cut it off, at the valve, after it has drained. Then all I would need to worry about is keeping the pad warm and running the pool when it is really cold.
    True L 45,000 gal Hayward IG vinyl pool. Hayward Tristar 2.40 THP; 1.5 FRHP/1.60 SF. Hayward Model # S310T2 Sand Filter. Aqua Rite T-15. Aqua Comfort 154,000 BTU Heat Pump. TF-100
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,621
    Re: Water seeks it's own level
    I'm wondering if that depends on how the slide is plumbed in? Got more info on that?
    ned8377's Avatar
    Apr 2015
    Wake Forest, NC
    242
    The pipe runs underground, presumably at the same level as the pipes that go to the returns. There is a concrete deck so the underground piping near the pool would be at least under that. By the way, the pad is way below the water level. I appreciate your help!
    mas985's Avatar
    Pleasanton, CA
    11,741
    Yes, the water should drain back to the water level in the pool when the pump is shut off.
    Mark
