Thread: Well here we go!
    justinfrancisjudd's Avatar
    Dec 2014
    Temecula, Ca
    135
    Well here we go!
    Thanks to some friends dogs that were here while we were swimming the other day i awoke to this. They knocked a sprinkler head off then the pool got about 8 mins of dirt and bark treatment this morning when they came on. Should have known better...
    Ive got all the bark out since but there was a good amount of dirt and crud that made its way in there also. SLAM time
    2015 Build, Stonescapes Mini Pebble-Blue Sea, 46.5'x23', 9' deep, Paramount IFCS on steps and shelfs, 8' spa with spillover, Quartzite Flagstone Coping and Patio, 3" Suctions and Returns, 1 skimmer, 6 Jandy LED Watercolor lights, Baja Shelf w/ diving rock, 2x 2HP Jandy VS E-Pump, Jandy LXI 400K BTU Heater Cupro/Nickel exchanger, Cartridge Filter, Grotto/Waterfall/ Slide, Jandy SWG, I-aqualink 2.0
    Jun 2014
    15,255
    Re: Well here we go!
    Regardless, that's still a very nice set-up you have there. SLAM away and get it back to crystal clear soon.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,643
    I bet it will take no time to clear that!
    What kind of filter do you have? I see everything else in your siggy but cannot find your filter.
    Since this is dirt and such causing this I would keep it at SLAM levels with the pump running the whole time to filter out the stuff for a couple of days then turn the pump off overnight so the stuff can settle to the bottom to be vacuumed out.
    Darn DOGS! I bet they were having fun too!
    Kim
    Dec 2014
    Temecula, Ca
    135
    Thanks guys!
    It took a week but its back to normal and as clear as the day before it happened!
    24/7 filtering x5 days, Filter is a CV-580 or something by Jandy. Has 4 cartridges internal. My filter pressure still hasn't risen the entire time on the filters which is surprising
    The dirt did not want to settle down to the bottom so I think thats why it took so long, Crazy thing is my salt cell is off the whole time and its been x4 days since I last added bleach, the FC was at 14 then and it was only down to 10 when i checked yesterday. I guess with the lack of sunlight in the fall takes a while to get it back down.
    My Chems
    FC was raised to 14 for the slam, 10 now and falling slow back to 4-5
    PH-7.2 for the slam, back to 7.5 now (if the higher Fc is reflecting it correctly)
    CYA between 30-40
    TA 70
    Salt 3200
    CH- 325
    Jan 2012
    'burbs of Augusta, Georgia
    7,368
    I hesitate to mention this but..... is your CYA always that low? For a SWG pool we do normally suggest it be a tad higher, such as 70ish. Of course you don't want it too high though...especially in CA where water replacement is verbotten. I mention this just in case you ever had problems maintaining your FC?
