Results 1 to 12 of 12
Thread: Daughters pool
    Daughters pool
    16 x 32 x 4 rectangular pool. Hayward sand filter and pump . I'm kinda at a loss testing with tf100 shows fc 30 ph 7.2 ta 130 cc 0 cya 30 pool is cloudy and with Taylor ch test kit the one with 2 vials ch and ph the ch side is orange never seen that
    AG 9000G vinyl-oval 15 x 24
    Hayward powerflo xl pump
    Hayward perflex DE filter
    TF100
    Wide mouth skimmer
    Direct sunlight all day
    W.PA/OH border
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Daughters pool
    At that high FC, the TC test (in the K-1000 dual tube for pH and TC) will be various shades of orange from pale orange at 10ish FC all the way up to deep pumpkin orange at 30+ FC.
    Isolated Spa - 345 Gallons
    JoyfulNoise's Avatar
    May 2015
    13,215
    Re: Daughters pool
    You can't test pH when the FC is that high. The fact that your pH is reading 7.2 is disconcerting because high FC makes the pH test read high. So the actual pH of the pool water could be much lower than 6.8.
    What was the pool chlorinated with??
    Matt
    Re: Daughters pool
    Pool ch with bleach and am aerating now to raise ph
    TF100
    Wide mouth skimmer
    W.PA/OH border
    May 2015
    13,215
    Re: Daughters pool
    Quote Originally Posted by dogdays View Post
    Ok. Wait for the FC to drop before making anymore chemical additions. High chlorine levels can skew all the tests (some more than others) but it's better to wait.
    Also, for chlorine, please use abbreviations FC, CC or TC. Using "ch" confuses it with calcium hardness (CH).
    Matt
    Re: Daughters pool
    Thank you will try and be patient
    TF100
    Wide mouth skimmer
    W.PA/OH border
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,535
    Re: Daughters pool
    Looks like you have a handle on what needs to be done. Patient is the word of the day for sure.
    Kim
    Re: Daughters pool
    Seems the previous readings were not correct nor did I know she added bags of shock. I took new readings
    Fc- 24
    Cc-0
    Tc-24
    Ph-7.8
    Ta- 130
    Ch-375
    Cya-70
    Tf-100 test kit
    Water is still cloudy, we just want to close for winter
    TY
    TF100
    Wide mouth skimmer
    W.PA/OH border
    May 2015
    13,215
    Re: Daughters pool
    What "bags of shock" was she adding and how much of it did she add? What city and state is the pool located in?
    Matt
    Re: Daughters pool
    Don't know type and quantity she is not here right now. Pool is located in Hebron, Ohio.
    TF100
    Wide mouth skimmer
    W.PA/OH border
    May 2015
    13,215
    Re: Daughters pool
    Well, your options are these -
    1. Wait for the FC to come down and try to deal with the cloudiness issue (it's very likely chemical in nature); OR
    2. Winterize the pool, cover it and wait until Spring.
    If you choose option #2, then I would advise that the pool be uncovered and opened as soon as the water temperature hits 50-55F consistently. That's below the 60F point at which algae likes to start to grow but it's warm enough to start up a pool. The reason I suggest this is because, right now, the pool is a bit of mess chemically speaking and with the high CYA there's a very good chance all that CYA could be converted to ammonia over the winter (by bacteria). If you wait too long in the Spring to open, you'll be fighting both a green swamp AND an ammonia mess both of which will require large amounts of liquid chlorine to fix. IN the meantime, it would be good to know what your daughter was shocking the pool with and then, come next spring, switch exclusively to bleach/liquid chlorine and stay away from the solid chlorine products.
    Matt
    Re: Daughters pool
    Thank you Matt I will let her know. I need to head home tomorrow and she will have to take over.
    TF100
    Wide mouth skimmer
    W.PA/OH border
