Results 1 to 14 of 14
Thread: pressure loss....
    Jun 2007
    Spring Hill, FL
    29
    pressure loss....
    When I connect my total length of vacum hose to the skimmer I lose about 2-3 lbs of pressure and the pump runs a little louder. When I connect the head (Hayward NaviGator) I lose even more (6-8 total). I disconnected the sections of hose and connected each piece of hose seperatly to see if it was a certain section that might be leaking and found none, each pice connected indiv experienced no pressure loss or change in pump noise. Any ideas??
    14K Gallon IG Diamond Brite Finish
    24SF DE Filter
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: pressure loss....
    Is this a new problem or has it always done this? When you connect the hose and the cleaner, the flow to the pump through the skimmer is restricted. Less water in means less water out so the pressure is lower. If you have a main drain or multiple skimmers, it shouldn't be a problem, as the pump can draw water from them. Many cleaners have flow adjusting devices to allow the pump to draw some water from the skimmer and whatever is needed through the cleaner.
    If it's a new problem, it could indicate a leak on the suction side of the pump someplace. The restricted flow causes lower pressure on the suction side, which could be causing air to enter through a leak. Do you get bubbles in the strainer basket or coming out the returns when the cleaner is hooked up?
    Jun 2007
    Spring Hill, FL
    29
    I have one skimmer that has two holes and a main drain (bottom of pool) I do not have or see a valve or switch to increase the suctiion of the main drain that I can tell. This problem seems to be relatively new that I can tell or has always been and I never really paid attention.
    24SF DE Filter
    SW Indiana
    9,198
    Quote Originally Posted by Edgie311
    A two hole skimmer has the main drain routed through it, so when you connect the vacuum hose you are drawing all of the pump water through the hose. You need a regulator valve or adjustable vacuum plate, both of which are available from Hayward.
    Jun 2007
    Spring Hill, FL
    29
    so should the second hole have suction also because I do not feel any suction?
    24SF DE Filter
    No, the second hole shouldn't have any suction. It either goes to the main drain or is plugged.
    SW Indiana
    9,198
    No, water enters the skimmer from the main drain via the hole closer to the pool, then all the water entering the skimmer goes to the pump through the second hole.
    ETA: Half a second late Jason. You beat me.
    Jun 2007
    Spring Hill, FL
    29
    Thanks, but still feel I am not quite grasping what you mean.......a simple plate to cover both skimmer holes that has a connection for the vac hose?[attachment=0:1krgdii1]850019b.jpg[/attachment:1krgdii1]
    24SF DE Filter
    SW Indiana
    9,198
    Water flows into the skimmer from the opening in the side of the pool and from the hole that connects to the main drain. If you place the vacuum hose in the rear hole in the skimmer, all of the water flowing to the pump is coming from the hose. Nothing can flow from the drain or through the skimmer opening. If you place a skimmer vacuum plate over the skimmer and connect the hose to the vacuum plate, then water can flow from the main drain and the hose. You usually need to make this setup adjustable to reach the prescribed flow rate for your Navigator.
    Jun 2007
    Spring Hill, FL
    29
    Would the plate go down just above the two holes or would it sit right above the skimme basket?
    24SF DE Filter
    A vacuum plates sits on top of the skimmer basket. That is another advantage of using one, the skimmer basket catches large debris so it doesn't clog your pump strainer basket.
    Jun 2007
    Spring Hill, FL
    29
    Thanks, because I was plugging the navigatr straight in is why it was going like it was on steriods (moving very fast and climbing the walls like an AdHd 5yo?)
    btw I have a birdcage so that is why large debris didnt make it obvious
    24SF DE Filter
    SW Indiana
    9,198
    Probably so.
    Mar 2009
    Woods of North Florida
    148
    JohnT,
    Just highjacking the thread to say I love your avatar! My favorite part of our morning routine is stopping the getting ready rush to see what the sheep and that dog are up to. I loved the monster tractor!
    24' Seaspray Evolution CLX Above Ground Pool (~13600 gallons)
    Pentair Sand Dollar SD60 / 22.5" filter / Maximum Flow Rate 60 GPM
    Pentair Dynamo Pump 1 1/2 HP
