Thread: CSI (Calcite Saturation Index)
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,255
    I am trying to grasp this concept, but having a tough time with the "Less than" and "Greater than" part.
    -0.6 until 0.6 (Is this good)? Thank you.
    Calcite Saturation Index - requires pH, TA, CH, CYA, Temp, uses Borate, Salt
    Less than -0.6 is suggestive of problems for plaster, tile, stone, and pebble pools.
    Greater than 0.6 is suggestive of problems for all pools.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    JoyfulNoise's Avatar
    May 2015
    13,200
    Re: CSI (Calcite Saturation Index)
    Those are the extremes. The scale is logarithmic which means that there's twice as much calcium saturation at +0.6 as there is at +0.3. Some other things to keep in mind is that pools don't typically see scaling until you get beyond +0.6, so scaling is very likely at +0.7 and almost definite if you hit +1.0. For spas with lots of aeration and high temperatures, scaling can be see at +0.3 in some cases.
    On the negative side, being between 0 and -0.3 is fine and even going to -0.6 is ok for a short period of time. However, extended periods of time with the water at or below -0.6 can lead to plaster damage (etching).
    Your pool is vinyl, so a negative CSI is really not an issue (although highly negative CSI means your water balance is probably not in a "happy" place). Positive CSI values are worse for vinyl because you can get scaling which will lead to a rough feel to your liner. SO for you, I'd say try to keep your CSI between -0.2 and +0.2 and don't really worry too much if you're negative.
    Matt
    Catanzaro's Avatar
    Jul 2014
    2,255
    On the negative, anything past -0.7 until -1.0 (for example) is bad and on the positive side anything past 0.7 until 1.0 (for example) is bad.
    Just want to make sure I am understanding this. A lot of forum posts have plaster pools. Even though I help, sometime I get caught up in CSI, which I believe is more important than vinyl pools (which I always understood). My CSI always seems to be -0.03, which almost seems to be perfect. It is only when the water temperature drops to about 30*, which is for a very short time, my CSI change is -0.51, which is not a big deal.
    I was having trouble interpreting the negative side, not the positive side. In reality, the negative becomes greater, not necessarily less. Less than is really greater than (if this makes sense).
    May 2015
    13,200
    For vinyl pools, negative CSI is not a big deal. Vinyl damage is typically driven by excessively low pH AND high FC such that the hypochlorous acid oxidizes the liner (bleaches out the colors) and the low pH weakens the vinyl causing embrittlement and cracking. Very high pH can cause vinyl to swell but both of those extremes would be hard to get to without the pool owner noticing something is wrong with the water.
    Remember, CSI is the degree to which the water is saturated with calcium carbonate (can absorb or emit calcium carbonate). 0 means the water is perfectly saturated, negative is under-saturated and positive is over-saturated. It's a representation of the thermodynamic driving force for calcium movement but says nothing about rate or initiation of the movement process.
    Matt
    Catanzaro's Avatar
    Jul 2014
    2,255
    Thank you. Now this makes more sense.
    Jan 2014
    Buckeye AZ
    807
    -1 is less than -.5, so I believe the wording is accurate.
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
