Thread: Kreepy Krauly and Multivalve Setting
    Hello,
    I am using my kreepy krauly for the first time. I am attaching it to my skimmer suction line directly. Can anyone tell me what setting my pump/filter should be on? Vacuum to waste, backwash or filter? I have a multivalve on a Hayward DE filter. Thanks so much!
    Pool Details: 40k Inground Vinyl Liner Pool with Mesh Safety Covering
    Jezza's Avatar
    Jan 2015
    Bunbury, WA, Australia
    882
    Re: Kreepy Krauly and Multivalve Setting
    Hi ajplello2003. I just run my Mako Poolshark on the filter setting from my skimmer suction line.
    11 000 gallons, IG, Fibreglass, Monarch Sand Filter, Davey Typhoon C100M 1HP pump, Davey Chloromatic Mc16CTO ESR SWG, Davey Pool Wall Climba Robot, Daisy Solar Cover,
    K-2006
    Quote Originally Posted by Jezza View Post
    Hi Jezza,
    Thank you so much for the quick reply. Now my only question is I'm assuming all debri will be pushed to my filter correct? In that case I anticipate needing to backwash and replenish DE quite a bit. Is that correct? I add my DE via my skimmer line so I'm assuming this may be a bit tedious. Thanks!
    Jezza's Avatar
    Jan 2015
    882
    Yep it just acts like your normal filter setting just with the debris being picked up by the Kreepy Krawley, rather than directly through the skimmer or manual vacuuming. I have not had experience with a DE filter but I am sure somebody will be able to help you out with that specific question shortly.
    K-2006
