Results 1 to 14 of 14
Thread: pump loses prime when vacuum is attached
    I'm having trouble when trying to vacuum the pool. I'm doing it the same way I've been doing it for the past few years, but suddenly the pump started losing its prime once the vacuum was used. I have removed and lubed the gaskets, but as long as the vacuum isn't attached, the pump runs fine. I don't have a "swivel end" to get mixed up which I read about in older threads, and there isn't anything lodged in the vacuum hose, plus the return flow appears to be ok. Both ends of the hose, the one attached to the vacuum head and the end attached to the skimmer (pool only has one skimmer) have cracks, but they're both under water all the time so can't be sucking air. Any ideas??? I'm preparing to put the house on the market and want the pool to look sparkling. Thanks for any suggestions. I'm stumped, and here come the leaves...
    6K gal., cartridge filter, AG
    Dallas, TX
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Re: pump loses prime when vacuum is attached
    You are filling it with water before you hook it up, right?
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Yes.
    Dallas, TX
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Then I would guess there is a hole in the hose or possibly in the pipe leading from the vacuum attachment point.
    I have examined the hose for any tiny hole and see none, and if it were a hole in the vacuum attachment point (i.e. the under-water hole to the skimmer), wouldn't it cause loss of vacuum all the time and not just when the vacuum hose was attached? I'm inclined to just buy a new hose, as I can't figure anything else out. Nothing seems logical.
    Dallas, TX
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Is it possible to post some pics of the skimmer and any other equipment you might think helpful.
    Thank you for your support. The new hose didn't solve the problem. I believe there may be an issue with the hard plumbing, as we're having drought here in TX and ground shifting. I've exhausted every other possibility. Thanks again.
    Dallas, TX
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Wish I could help you further. The only thing that comes to mind is to check things like the seal on the pump basket.
    Jun 2014
    14,970
    If this continues to become a nuisance for you Greta, I would encourage you (as Bob noted above) to post a pic or two of your equipment. That may help us a bit. Right now it's kind of hard to visualize what equipment (pump, skimmer, plumbing lines, etc) you have to work with. There are so many different set-ups out there, maybe something will jump-out at us with a picture.
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,245
    Please tell us if you have 1 or 2 Skimmers and a Main Drain:
    Try this:
    Put the round plate on the skimmer. This should be sealed tightly immediately from the suction. Then set everything up and attach the vacuum head to the pole and hose. Run the hose to a return and fill up with water until the vacuum head lifts itself off the ground. Take your hand while still underwater and plug the vacuum hose not to introduce any air into the hose. Go to the skimmer and quickly put hose on vacuum plate. Let is sit there for a minute or so. Watch the return jets for air and when all the air is gone (which should not be more than a minute, you are ready to go).
    Because we do not know your system, do one of the following. Slowly close the other skimmer all the way and you should feel the resistance in the vacuum head. If not, then close the main drain slowly (completely). You should have a lot of resistance at this point where you can no longer move the vacuum head freely. If this is the case, then carefully back off the main drain and open up all the way. If you still have resistance, then work slowly on other skimmer.
    Essentially, what you are doing is creating more suction on the vacuum side and reducing in other areas. I can edit this post once I know more about your pool..
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    Thank you, I will, as soon as I can.
    Dallas, TX
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Cat - She has a dedicated vacuum line. See her comment in post #5.
    Thanks Catanzaro. I have only 1 skimmer and no main drain. I have been using the vacuum every other day for over 3 years now. This problem has just suddenly occurred, which tells me it has nothing to do with how I'm filling the vacuum hose. The guy at the local pool store also showed me an alternative way to fill the hose, which I followed, but the pump still lost its prime. I will post pics in a few days when I'm at the location of the pool (I have moved), if I can't find any local help. Thank you again. I really appreciate all the replies!
    Dallas, TX
    Catanzaro's Avatar
    Jul 2014
    2,245
    I guess at this point, only pictures of the equipment would help. Missed that you have an AGP, but concept should be similar.
