Thread: Can I drain my slide by taking plug out?
    ned8377's Avatar
    Apr 2015
    Wake Forest, NC
    242
    I'm posting this here since this is the area for pipes. I want to keep my pool open this winter but would like to not have to run the slide to keep it from freezing. There is a black plug below the on off valve for the slide and for the other pressure side return jets. It looks like it can be unscrewed but I'm not sure. Since the equipment pad is below the pool I'm thinking that if I unscrew it and the valve is turned off, the water will drain out of the pipe and then all I have to do is keep that valve closed during the winter. Does it unscrew? Thanks!
    True L 45,000 gal Hayward IG vinyl pool. Hayward Tristar 2.40 THP; 1.5 FRHP/1.60 SF. Hayward Model # S310T2 Sand Filter. Aqua Rite T-15. Aqua Comfort 154,000 BTU Heat Pump. TF-100
    ned8377's Avatar
    Apr 2015
    Wake Forest, NC
    242
    Re: Can I drain my slide by taking plug out?
    Would this be where a chlorinator line would be hooked in?
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    You have a better view of this plug that we do but I imagine that if it was inserted, it can be taken out. Now as to whether or not it is threaded, I cannot tell. I'm not sure why the slide line would be a good place for a chlorinator but I suppose it could be since it is a return line into your pool.
    Even if you drain the line via the black plug and close the valve, you'll still have some water in the pipe below the black plug that would either need sucked or blown out I would think.
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
    ned8377's Avatar
    Apr 2015
    Wake Forest, NC
    242
    Thanks Agent 99. Just so it is drained from the slide and at or below the pool level, I am fine. The equipment pad is way below the pool level so it should drain. Thanks again!
