Thread: Question about leak in skimmer wall
    Feb 2012
    Dallas, Texas
    56
    Just had a guy come out to investigate the substantial water loss I've suffered in my pool over the last couple of months. He found a very long "hairline" crack in the skimmer wall. He said he could patch it with epoxy, but he didn't think the patch would hold for long because the crack is so thin and long he might not be able to get epoxy to "stick good." He recommended a fairly major job that involved draining the pool, staples, reinforcement, etc.
    Since the difference in patching and the big job was about $2000, I went with the patch. I figured that it was worth a shot for under $500 total. If it ends up not holding, I paid less than $500 to know for sure that the leak is there and that the big fix will stop the leak.
    Question - I know there's not a lot to go on here, but was he trying to upsell me the big job or does his explanation for why the patch won't hold make sense?
    Thanks
    IG plaster pool, 16000 gallons, Hayward DE6020 filter (120GPM) , 2.0 HP 230v single speed 1.3SR motor on Sta-Rite Max-E-Glas 1 pump, Polaris 280 (with Polaris 1.5 HP booster pump), spa.
    Feb 2012
    Dallas, Texas
    56
    Re: Question about leak in skimmer wall
    OK, the guy set up the valves so that the skimmer is off and the pool is circulating through the returns. Lost 1-2 inches in 8 hours. Looks like he was wrong and it's the return line. What does that mean? 5 figures?
