Results 1 to 7 of 7
Thread: Stone ledger wall
    Feb 2015
    Morgan Hill
    3
    Stone ledger wall
    I am in the process of having a pool built and have some questions.
    We are on a hill and ended up with a 20' x 5' retaining wall that the pool goes right up to. We are planning on using ledger stone on the wall with a water spill way, almost the entire length.
    I want to extend the ledger stone all the way down to the bottom of the pool. I thought it would look very striking. This would eliminate the tile water line, however as we are putting in an automatic cover I would still have that straight like. Anyone ever done this. The pool will be a SWP...
    Thanks, appreciate any feed back.
    Aug 2014
    Houston tx
    2,525
    Re: Stone ledger wall
    Welcome to TFP! I can't help but I'm sure someone will be along shortly who can. It would be helpful if you could provide pics of your space.
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Feb 2015
    Morgan Hill
    3
    Can't load a picture... Says I don't have permission, I am logged in..
    Jan 2012
    'burbs of Augusta, Georgia
    7,364
    Try uploading it to TinyPic - Free Image Hosting, Photo Sharing Video Hosting and then copy the link on here
    Aug 2014
    Houston tx
    2,525
    Create a Photobuckrt account and then paste the IMG (it's on the right) into the post.
    Marla
    Feb 2015
    Morgan Hill
    3
    Apr 2013
    Sacramento, CA
    2,769
    First you need to have a long talk with your PB.
    Most PB use some form of fake rocks ,usually unite, when exposed to the pool. Real rock is rare because of the scum line and the unpredictability of how it will handle years of exposure to chlorine acid and in your case salt.
    So see what your PB says.
