Thread: Recommended filteration cycles?
    Oct 2015
    Kelowna BC
    47
    Just started setting up this hot tub for the first time. It comes factory-programmed with 4 x 30min cycles per day. I've heard that 4 hours per day is ideal? So I've jacked it up to 4 x 1hr cycles, is this good? Thanks.
    Sundance Calypso Hot tub 1500 L, 2 pumps, Taylor K-2006 test kit
    Jan 2012
    'burbs of Augusta, Georgia
    7,367
    Re: Recommended filteration cycles?
    I've got a Sundance hot tub also and never altered the factory settings for the cycles. It works great just as is. I've never read any place that "four hours is ideal" before.
    So while of course what you're doing won't hurt, it isn't necessary either.
    TheBraLady's Avatar
    Jun 2015
    Concord, NC
    177
    Great question. I hadn't thought too much about it. Ours was programmed to run twice a day for 2 hours...I haven't "messed" with that...yet.
    Pool Completed 8/2015 18'x36' Gemini shape 3.5' - 8', 19,200 gal IG vinyl, Hayward Max-Flo 1.5 HP 2-speed pump, Hayward Pro Series 300-lb sand filter, Hayward AquaPlus SWG, NO Autofill, Dolphin M400 robot, Taylor 2005 test kit, 434 gal Bullfrog A7L spa
    wjr75's Avatar
    Jun 2013
    IL
    836
    I run our 900 gallon built in twice a day for two hours each after the main pool is closed. Has worked for four years so I'm sticking with it.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Jul 2015
    South County, Rhode Island
    36
    With the exorbitant price of electricity here in New England, I adjusted my 180 gallon tub to survive on 30 minutes filtration twice a day. The numbers are great and the water still sparkles. I only lose 2 or 3 degrees between cycles and it recovers the temp within 10 minutes. I would try and do the math to see how many turnovers you get per hour and go from there.
    2015 Bullfrog 131 180 gal Spa Indoor, TFP bromine fed, Taylor K-2106
    2012 2500 gal. Round vinyl AG Pool, Hayward Easy Clear Filter System, chlorine
    1994 Rubbermaid 175 gal horse tub, still looking for advice on algae problem.
    Oct 2015
    Kelowna BC
    47
    Cool Thanks for all your replies!
