Thread: Main drain suction
    new-to-poolcare's Avatar
    Aug 2015
    Bellflower, CA
    19
    Main drain suction
    I found the suction from the main drain to be very low. Do I need a plumber? Thank you.
    26,000 gallon, in-ground concete; Pentair Superflo VS pump; Pentair Quad D.E. Filter; Polaris 180 Vac-Sweep with booster pump
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,025
    Re: Main drain suction
    Hi,
    It depends on how the drain is plumbed.
    Many times, the pool builder will run the main drain pipe, into a port on the bottom of the skimmer. This type of set up means the suction on the main drain will be very low.
    Hi,
    If thats how the drain was plumbed, then the suction of the drain is probably as good as it will ever be.
    Divin Dave,
    Mar 2015
    Dallas, Texas
    133
    What should it be like? Makes me curious I swam down and can't feel suction at all...
    Build in progress: 31x18 GI (17,336 gallons) / Diamond Brite French Gray finish / Flagstone Coping / 30ft weeping wall with 7 stations plumbed / Salt Finish Deck / Pentair EasyTouch Controls / Pentair IntelliFlo Variable Speed Pump / Pentair D.E. Filter 60sft / Polaris Automatic Pool Sweep w/ Booster Pump.
    mas985's Avatar
    Pleasanton, CA
    11,743
    You shouldn't feel anything or very little if it is a VGBA compliant MD. They are designed that way on purpose and are not really meant to pull in debris, just water.
    Mark
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    It is pretty low. Our main drain is plumbed to a valve on the equipment pad. Even with the valve turned all the way to drain and the pump turned up to 2500 rpm the suction is pretty low. When I brush my pool I use these settings and some of the dust blows right past the drain every time. I have to brush back to the drain multiple times for all the dust to get sucked up.
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Read the link in my signature about my Fake Main Drain. It could be low as the folks above pointed out or it could be shut down or perhaps clogged. Hard to say without more info on your system.
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
