Thread: Is this coating Cooldeck???
    Jun 2012
    western NY
    1,562
    I woke up this morning to this...
    Is this some sort of Cool-Deck coating. It looks like it would be a bit on the cool side.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    JoyfulNoise's Avatar
    May 2015
    13,258
    Re: Is this coating Cooldeck???
    Hahahahaha....definitely cool deck....
    The air temp this morning here in the desert is a chilly 61F, so I'll have to be sure and wrap up in a warm wind-breaker when I go outside. Heck, my pool water won't break 79F by mid-day anymore....winter is certainly upon us
    Matt
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Ohhh booooo! That is not a good deck coating at all!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,025
    You got me!
    Divin Dave,
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Yep, the weather is getting cooler. I had to put the bubble wrap on top of the pool. The solar alone wasn't keeping the water in the 80's without a cover. The forecast high tomorrow is only 86.
    chiefwej
