Thread: Small leak from hot tub motor
    Jul 2012
    Herndon, VA
    419
    I noticed a small bit of water near the hot tub this morning, so I checked it out. Water is spraying out in small drops from the motor.
    Looks like this is the problem:
    How to Change Your Hot Tub Pump Seal - YouTube
    Is this something I should call the repairman for?
    8,000 gallon, in ground, fiberglass pool with a cartridge filter.
    Aug 2015
    Maine
    45
    Re: Small leak from hot tub motor
    They are easy to change, simply nuts and bolts. Also, if you have room and they are not there, it is a good time to install isolation valves.
    Jun 2015
    Wildomar, California
    423
    If you do not have shutoff valves, it will require you to drain the spa.
