Results 1 to 14 of 14
Thread: Pressure drop on sand filter
    ned8377's Avatar
    Apr 2015
    Wake Forest, NC
    242
    Anyone know what would cause the pressure to drop about 4-5 psi on the sand filter for no apparent reason? It has not been back washed etc. Could it have developed a channel through the sand? I've seen it do this once before and then it would go back to normal pressure after a while. Thanks.
    True L 45,000 gal Hayward IG vinyl pool. Hayward Tristar 2.40 THP; 1.5 FRHP/1.60 SF. Hayward Model # S310T2 Sand Filter. Aqua Rite T-15. Aqua Comfort 154,000 BTU Heat Pump. TF-100
    Jan 2012
    'burbs of Augusta, Georgia
    7,367
    Re: Pressure drop on sand filter
    Did you remove a cleaner or turn any of the valves? You didn't backwash before the drop I take it? If you're concerned about sand channeling you could always pop it open and look. Perhaps give it a little clean while in there..... Just a suggestion
    ned8377's Avatar
    Apr 2015
    Wake Forest, NC
    242
    No didn't change anything. Actually, the only other time I noticed it was after a back wash and then a couple of hours later it was back to normal. This time, I have not back washed. Went outside to check things and noticed pressure had dropped. Thanks!
    30,431
    PSI drops because of decreased flow on the suction side. Of course, a faulty gauge can be an issue, but typically, you will find some obstruction somewhere between the impeller on the pump to the skimmer(s).
    Most folks assume the worst and think it is the underground pipe.........while it can be, it almost never is.
    What have you inspected so far on the suction side of your system.
    ned8377's Avatar
    Apr 2015
    Wake Forest, NC
    242
    Ok, I went out and emptied all the skimmer baskets and pump strainer. Not sure how to check the impeller. Ended up with same pressure. Then I backwashed as usual and it went back to same pressure. You are right that an obstruction could decrease pressure since turning off the main drain or skimmer will do the same but they are all on. I have a return jet in the shallow end that blows close to the top of the water so I can visually see the circulation and it is better than it has been in the past. All the skimmers seem to have good circulation. When turning off the main drain pressure drops further as it should.
    I've always had a problem with the pressure running too high in my opinion at about 26 psi after a backwash. I would wait for it to get up to no more than 35 psi before backwashing again and it would always go down to about 26-27 psi. Now it is running at 20 psi which is more in the range of where it should be.
    If the flow, from the return jet, in the shallow end is, visually, at least or greater than it usually is and all the skimmers seem to be sucking normally, am I right to assume there is probably no obstruction?
    Thanks for your help!
    30,431
    Why? What is different from when it was at 26 psi?
    Decreased pressure (that's you) and an increase in flow (that's apparently you, too) indicate you have removed a restriction from the pressure side of your system.
    When did that drop in psi occur?
    ned8377's Avatar
    Apr 2015
    Wake Forest, NC
    242
    Maybe the gauge is defective. We had weeks of rain starting around Sept 24 here in NC. Ever since then there have been droplets of water inside the gauge that won't go away. Went out and started the pump this morning and now pressure has moved from 20 psi to about 24 psi. You can see where I used to have it set at 26 to about 35.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Moisture inside the gauge, is usually a sign of a gauge in need of replacement. TFTestkits.net sells a real good one that is glycerin filled. Lots of folks here have one and really like it.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    domct203's Avatar
    Jun 2015
    CT
    3,596
    If this was my filter I would change the gauge for one that I could read.
    I have installed one of these on my sandfilter, it's a high quality gauge at a reasonable price.
    http://tftestkits.net/Flow-Meters-and-PSI-Gauges-c12/
    HTH,
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    seconded on the tftestkits glycerin guage...it's a very good price...I just got one a month ago...very happy with it.
    Dolphin E10 Cleaning Robot.
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    I third the Glycerin filled gauge, got one this year from TFTestkits and there is no guessing as to the real pressure
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    ned8377's Avatar
    Apr 2015
    Wake Forest, NC
    242
    What does the glycerin do? Does it keep the water out? Also, would I not need a gauge that goes over 30 psi? I guess my gauge has always been registering too high. Thanks for the advice.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    I think it might have something to do with withstanding lower cold temperatures as well as smoothing out the needle when it moves, but one thing I did not like about it then
    changed my mind is the bubble showing at the top of the rear mount one.
    Then I realized the left and right edges of the bubble is the exact area where markings would be for "time to back wash"
    and "just backwashed" areas of the gauge...at least on my pump/filter setup it is.
    Most residential pools should not need a gauge going beyond 30.
    30,431
    The glycerin protects from freezing down to around 4 degrees F. (I think). The air bubble in the gauge is mandatory.....pressure equalizer.
