Thread: What to do with phosphate remover?
    Saturn94's Avatar
    Mar 2015
    Virginia
    496
    My apologies if this isn't in the right place.
    I have a bottle of "Phos X" left over from a closing kit I bought a few seasons ago (I no longer use the stuff after learning it was unecessary). I can't return it so it's just sitting in the closet.
    How can I get rid of it? I guessing pouring it down the drain isn't a good idea. Can I add a little at a time directly into the skimmer (to avoid clouding the pool) over time until it's gone?
    I don't know anyone I can give it to.
    Suggestions?
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
    JoyfulNoise's Avatar
    May 2015
    13,171
    Re: What to do with phosphate remover?
    Does your county have a hazardous chemical collection program?
    Twice per year Pima county has one where they let homeowner bring in paints, household and pool chemicals for hazardous waste disposal.
    Matt
    Saturn94's Avatar
    Mar 2015
    Virginia
    496
    I can check into that.
    Donldson's Avatar
    NW Ohio
    2,880
    I don't know if phosphate reducer can go bad, but if not I would hold on to it. If you ever have a situation where the FC might dip (vacation, acid treatment, etc) then it can be helpful to avoid algae.
    Phosphate reducers are one of those things where I wouldn't recommend buying it, but if you already have it then it can come in handy someday.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,245
    I gave mine away to the local pizzeria, in exchange for a Pizza. It used to make my water cloudy.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
