Thread: Water feature winterizing
    Sep 2015
    WI
    4
    Hello! What does everyone do for closing down water features? I figured blow out those lines but do you have to unscrew the brass (assuming it is brass) piece somehow? or need to try and get antifreeze into the smaller water feature hole as much as possible with a funnel? Would antifreeze cause any adverse effects to the brass?
    This is the kind of water feature I mean: http://www.sevenseaspools.com/assets...r-features.jpg
    Thanks! First time closing so want to make sure I don't majorly overlook something but TFP has already been awesome to figure this out!
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,255
    Re: Water feature winterizing
    If that is your pool (Very nice). All you have to do is blow out the lines. If you unscrew the brass piece, I would go to a hardware store and find a closed cap for each one. Others may have another idea. If you can find something to plug them with, please use non hardening joint compound so there are no issues in the spring.
    Amazon.com: Oatey 31230 Pipe Joint Compound with PTFE with Brush, 4 fl.Ounce: Home Improvement
    Maybe unscrew one and take a picture and send over. Thanks!
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    Sep 2015
    WI
    4
    Thanks for the reply! That is not my pool but the best example I could find of the water feature I had I ended up putting some antifreeze at the equipment pad and then pushing the fluid with the shop vac on and off quickly with adding more. Eventually I had some come out of the water feature and then just maxed it out with what I could before closing the valve. Should do the trick I would think. The biggest pain for the first close was dealing with the cover I think
