Thread: Spray deck with or without coping?
    JamieP's Avatar
    May 2011
    Waxahachie, TX (south of Dallas)
    1,135
    I've just begun to consider acrylic spray deck for our pool build and was wondering if anyone has any recommendations for using a cantilevered edge vs precast concrete coping with the spray deck for the rest of the concrete?
    I've seen several pictures on here of the former, but none with spray deck and separate coping (of any kind.) If you have pictures of either, and an opinion on the pros or cons of each, I would greatly appreciate it!
    Also, we are aiming to make the brushed concrete decking cooler than leaving it as is. Will a light to medium spray deck color help with that here in Texas?
    Thanks!
    28,000 gallon freeform, Stonescapes Tropics Blue Minipebble with abalone, 3.5' to 8.5' depth. 2 skimmers, 5 returns, dedicated vacuum port, Dolphin Z5 robot. All Pentair equip: EasyTouch 8, IC60 SWG, VS pump, 520 Cartridge Filter, 3 Intellibrites, 2 Color Cascade Bubblers. TurboTwister Slide and 8' Salt System Jump Board. TF-100. My Jan-Mar 2016 build:
    Waxahachie, TX Owner Build - A race to beat the baby!!
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Re: Spray deck with or without coping?
    There are some examples of both kinds on this site.
    DEV Xcel Surfaces Real World Examples
    Are you going to have a salt pool. If so I recommend a cantilevered edge. That's what I went with. If you must have a coping, take a look on the web site, there are several that they have also coated with the textured acrylic. It is the safest surface for a salt pool. Mine is ten years old and looks like new. After nine years it was starting to look just a bit faded so I just rolled a new top color coat on an voilą it looks better than new. About $100 for a five gal can and one and a half days work.
    chiefwej
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    There are some examples of both kinds on these sites.
    Pref Deck | An acrylic deck coating manufacturer
    Are you going to have a salt pool. If so I recommend a cantilevered edge. That's what I went with. If you must have a coping, take a look on the web sites, there are several that they have also coated with the textured acrylic. It is the safest surface for a salt pool. Mine is ten years old and looks like new. After nine years it was starting to look just a bit faded so I just rolled a new top color coat on an voilą it looks better than new. About $100 for a five gal can and one and a half days work.
    chiefwej
