Results 1 to 12 of 12
Thread: iRobot Verro 500 PowerScrub
    had anyone use this rrobot before?
    i find it in 470USD, also really good work
    Swimming pool equipment and spa accessories vendor
    http://www.jackbo.com
    jackboken@msn.cn
    budster's Avatar
    Dec 2008
    Savannah Historic District
    272
    Re: iRobot Verro 500 PowerScrub
    Hmmm. Made by the same company that makes the Rhoomba. I'll pass on the comment I would prefer to make!
    http://www.swimmingpool.com/
    "Leave the gun...take the cannolis"
    30,432
    It also appears to use the same power source as Blue Diamond. For that matter, the same drive belts as Blue Diamond.
    I think there is probably only one manufacturer in the world that makes all these different cleaners. They simply redesign the shell but the guts are the same. I'm pretty sure they deliver them to the pool stores in black helicopters, too.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Sep 2007
    Toronto
    106
    I recently purchased an i-robot Verro 500 from Costco Canada. I have considered many factors before taking the plunge. In this country, only a limited brands of robotic pool cleaners are available. The Verro 500 costs $999 Cdn, a Blue Diamond costs about $1,200 from U.S. online retailers, plus delivery fees, import duties, exchange rate, the total is about $1,700 Cdn. Costco has a good return policy, returning something across the border is definitely an issue. Someone from work has an i-robot floor vacuum, one time she had a problem and i-robot was very good at providing warranty service. The Verro 500 is i-robot's current top model pool cleaner, the design is quite similar to the Blue Diamond which also used PVS rollers. The Verro 500 is made in Israel, could someone who has a Blue Diamond check where it is made. If it is made in Israel, most likely both machines are made in the same factory. I probably got a good deal.
    OH TWINS
    San Juan 8500 gal Fiberglass Pool, Sta-Rite Max-E 1 HP pump, Star-Rite System 3 Cartridge Filter 300 sq. ft,
    Sta-Rite Max-E 200,000 BTU gas heater, Aqua Logic SWG with P-4 panel. Goldline wireless remote control,
    3 Jandy Neverlube Valves with Goldline motorized control, iRobot Verro 500 pool cleaner
    5 Poolstar 1000 LED Lights, LED strip light at waterfall, Prozone Ozonator PZ7 with degasser column,
    Jandy Auto Waterfill, Aquamatic motorized pool cover, Poolbuster Max CC handheld vacuum.
    china had the copy one about that irobot,it sell 420-520usd ,
    jackboken@msn.cn
    I own the iRobot Verro 500 and love it! On my 3rd year.
    The only thing is that it works so well, it ends up with a really dirty filter (sock type thing) and I find myself spending a lot of time with the hose trying to clean it off.
    It does well for about 99% of the pool -- I usually find myself brushing the steps and tight corners to agitate the sediment back into the pool so the robot can reach it, or it ends up in the filter.
    Hayward S220T Sand Filter, Hayward Max-Flo 1 HP Pump, 14,000 Gal Vinyl Inground
    Jul 2007
    Westcher, NY
    9
    Most of the time I just rinse my dirty filter bag in a bucket of pool water. I usually have to do 3-4 changes of water.
    Rich
    28x52 In ground, former cement pond (really) about 43.5k gallons
    Hayward EcoStar VS pump
    Hayward Pro Grid DE7220 DE filter
    Pool Pilot Digital 220 with the SC60 cell,
    4 returns, 3 skimmers and 2 bottom drains
    Raypak Rheem PMHP 8300TI 137k btu heat pump
    Liquid Solar blanket
    Aquabot T4 Turbo RC.
    Yes, this looks very much like the Blue Diamond. I did notice that the warranty is only 1 year though - BD has a 4 year / 400 cycle.
    BTW, there's a good deal at HSN dot com for the Verro - it's under $1K, free cart, and you can put it on 4 equal installment plans. No, I don't work for them or affiliated with them, I just saw the link when I googled Verro 500. But again, it's only a 1 year warranty, so you may want to factor in the extra 3 year warranty cost when price comparing to the BD or similar models.
    30K gallon, In-ground Gunite
    Central NJ
    After much research and contemplation, I decided to purchase the Verro 500 from HSN because I found a great deal (PM me if you iwant info on how to save an extra $75 and 4% cash back). I've determined that the Verro is either a non-remote BD or the BD Pearl based on pictures and specs.
    As I've posted before on this board, I briefly owned a BD Remote last season which I ended up returning. So why would buy another one from potentially the same manufacturer? Well, when it worked it worked great! I'm also not buying the remote version again because I suspect that the added complexity (required an extra motor and system controls for the remote functions) was what was causing my original BD Remote to malfunction. I'm also saving more than half of what I would have spent if I went with the BD Remote again. Granted, I'm losing the remote function, and the quicker 1 hour clean time, in this economy I couldn't justify spending twice as much, and perhaps winding up with the exact same problem. So in all, I think BD makes a good product compared to the other robot cleaners (based on numerous reviews I've read and my personal experience of a one that malfunctioned early in its life, but worked excellent when it did), and perhaps this rebranded version will fare better. And I don't have as much money tied to it.
    Then again, the Verro may not be made by Water Tech (makers of BD) at all!
    I'll post my experience to the board in about a month after I've had some good time with it... assuming it's still working
    Central NJ
    marthas_ear's Avatar
    Mar 2009
    Texas (Central)
    65
    Question- would this action tend to raise ph from aeration?
    we have high ph
    Regards,
    Martha in Texas
    17K gl-15'X34' IG, Fiberglass, Pentair: Intelliflo VS 3HP pump, PAL 2000 underwater lights, DE60 filter, Intellichlor IC 20SWG, Poolvergnuegen Suction Pool Cleaner2009 build date; TC100
    Ottawa, ON, Canada
    153
    Any more comments on it? it's on sale at costco canada for $1k - $130off at the end of the month and I'm tempted.. on the other hand, it's my first year with a pool and I don't mind vacuuming it yet!
    19.5k gallons in ground, P4 panel with turbocell SWG, 1hp Hayward superpump II, sand filter, Heater low nox 250k btu heater, solar cover on rocky roller
