Results 1 to 8 of 8
Thread: thoughts on these series of videos on closing your pool
    jfpool's Avatar
    Jul 2015
    Huntsville, AL
    22
    i am thinking of using these videos in conjunction with the TFP written instructions to close my pool this wkend. However, I was hoping some of the experts could give a review on the video series in the link below.
    http://www.monkeysee.com/play/11841-...er-water-level
    Pool Size/Type: ~16k/IG fiberglass
    Filter: Sand
    Sanitation: Pentair IC-15
    Test Kit: TF100
    City Water
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,256
    Re: thoughts on these series of videos on closing your pool
    The video is great to watch just so you have an idea of the actual concept on what needs to be done, but it is not the answer. The TFP instructions are excellent in how you should close your pool, although you will need to understand your plumbing. The video shows only that pool.
    A couple of questions:
    Q: What type of blower air compressor are you using?
    Q: Where exactly are you hooking it up to?
    Q: How many main drains, return jets and skimmers to you have?
    Q: Are you using black rubber plugs or duck plugs?
    Q: What valves do you have that operate the MD, returns, and skimmers?
    You can push air through the system, either at the equipment pad or through the skimmer. The filter should be on recirculate. Maybe sending over some pictures of the plumbing from front and side views would be helpful. We can then move forward.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    Quote Originally Posted by Catanzaro View Post
    Eh, as a new pool owner I sort of thought pool school articles on closing/startup/equipment as well as metals were lacking in comparison to all the great info on chemistry.
    Helpful Links: Pool Chemistry 101 - Recommended Levels - Recommended Chemicals - FC/CYA Chart - SLAM Instructions - Pool Math
    Test Kits:
    TF-100 - Taylor K2006 - SpeedStir Upgrade - Taylor K-1766 Salt Test
    My Pool:
    28k IG built May 2015 - Autopilot SWG - Pentair VS Pump/DE Filter/Heat Pump
    Apr 2015
    South Central PA
    297
    Quote Originally Posted by pinguy View Post
    I would agree....things that seem so obvious to the seasoned pool owner can baffle a beginner....I had the local pool company close (filter and lines only), watched what they did, and learned....there are different ways pools are plumbed, so my questions were my-pool specific...
    20000 gallon vinyl liner in ground pool
    16' X 34' rectangular diving pool
    Hayward Pro Grid DE Filter
    Hayward 1 hp Super Pump
    TF-100 Test Kit Stenner 45MPHP10
    Catanzaro's Avatar
    Jul 2014
    2,256
    So your pool is closed?
    We can still help you get an idea on what to do with your pool. If the pool company closed the lines and winterized the filter, then in the spring when temperatures break, you can open up your own pool (kind of). Just remove all the fittings and open up all the valves (like normal). Then you can practice closing your pool and not have to worry about freezing temperatures. There will be no reason to pay a pool company a lot of $$$ to turn a few valves and add some bleach in the spring.
    If you can please answer some of my questions, and possibly add some pictures of the equipment pad, we can go from there. A front view and side view of the equipment pad is best.
    I understand your questions are specific towards your pool, and your are correct stating that pools are plumbed differently, and this is why we will need a configuration of your set up in order to move forward. Thank you.
    jfpool's Avatar
    Jul 2015
    Huntsville, AL
    22
    1) bought a used cyclone vac/blower.
    2) hooking up to skimmer (have two skimmers and will probably blow out from both just to be safe)
    3) have one main drain in pool and a drain in the spa (plan to totally drain spa and blow out spa drain)
    4) black rubber plugs
    5) combination valves
    I will try to get some photos soon
    Filter: Sand
    Test Kit: TF100
    City Water
    Catanzaro's Avatar
    Jul 2014
    2,256
    If you are pushing air through the skimmers, after you close the first skimmer, then work on returns, spas, and lastly on the main drain. With the Cyclone, you can keep everything open, including the main drain. As you plug each area, the next area will start bubbling, and so on.
    The filter will need to be on "recirculate". Here is some information on winterizing the filter:
    WINTERIZING
    1. Completely drain tank by unscrewing drain cap at base of filter tank. Leave cap off during winter.
    2. Depress Vari-Flo control valve handle and rotate so as to set pointer on valve top between any two positions. This will allow water to drain from the valve. Leave valve in this "inactive" position.
    Remove other adapters and fittings on pump and filter. Store for the winter.
    Jul 2015
    Western NC
    115
    Those videos are excellent. I now understand several things that we have done wrong repeatedly over the years, including this year.
    23,000 gallons IG gunite, pebble (I think)
    Hayward SP2610X15 1.5 HP Pump, Hayward sand filter
    Mineral Springs SWCG (it's actually Hayward/Goldline), Hayward Goldline T-CELL-15
    Polaris pool cleaner (with booster pump)
    TF-100, SpeedStir, K-1766 Taylor Salt Test, Lamotte Borate test strips
