I have a H2X 19' Trainer Deep SwimSpa, Model 1270. ECO PUR water filter system. 231" X 94" X 60". SwimSpa. Spa side capacity = 225 gallons, Swim side capacity = 2045 for a total capacity of 2270 gallons. Ozone system, 4 pumps, 48 jets.
Question #1
Should I always run the pumps for a time before pulling a sample of water to be tested? or is it best to pull the sample before pumps run (they run every 30 min for 30 sec to check H2O temp)?
Question #2
Because this unit has two separate chambers (spa side and swim side), with varied temps (102 spa side and 88 swim side), should I keep readings the same for both? (I have read that more aeration causes PH to spike)
Clarification Question #3
Boric acid - PH stabilizer and water softener per se?
Question #4
IYO, what is the most effective product to use when I drain the unit?
I appreciate any and all suggestions/recommendations,
LakeLizard
Question #1
Question #2
Question #4
LakeLizard
