Results 1 to 8 of 8
Thread: Winter Cover for 12x24 Above ground intex
    May 2015
    Harrisburg/ PA
    4
    Hello! I'm hoping someone out there has a great suggestion on how to cover this pool!! We took it down last year but this year we put a deck on one end of it and want to leave it up. It is a 12x24 rectangular pool. I was told I would have to have a winter cover "custom made". We live in Central Pa. Please help!!
    Jun 2015
    Stockholm, Sweden
    250
    Re: Winter Cover for 12x24 Above ground intex
    I'm using a regular tarp over some floating, tied down jugs
    Intex Ultra Frame 24'x12'x52" (732cm x 366cm) rectangular pool
    Intex SF80220RC (1600 GPH) pump/sandfilter
    Intex SF10220 (1050 GPH) pump/sandfilter driving the
    Intex Automatic Pool Cleaner
    Intex 8220 ECO SWG, Brilix XHP100 9kW heatpump
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Quote Originally Posted by DFam View Post
    Winter covers don't seem to be anything more than a heavy duty tarp. Do you have an Ollie's in your area? they seem to have tarps at good prices there, or even a tractor Supply would have them.
    Jul 2014
    Oakbank, Canada
    389
    Any city with lots of trucking company's will most likely have a tarpaulin shop. Look in the yellow page phone book, and they can make you a very heavy duty one up to the size and shape you need, and place as many grommets as you need around it. Will last you for years.
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
    May 2015
    Harrisburg/ PA
    4
    Thank you all! I found a heavy duty tarp at Home Depot, 16 x 32. Is that the right size for a 12 x 24 pool? We are going to drain the pool just under the intake valve and cover. How many "air pillows" should we use and what do we do when the snow comes? Sorry if I sound completely clueless, but I am new at this!!
    LOL
    May 2015
    Harrisburg/ PA
    4
    We do have an Ollies but they don't have the size we need. I found one at Home Depot! Now I just have to figure out the air pillow thing and I guess use the Water Jug system to hold the tarp down.
    Thanks for your advice!
    May 2012
    Montville NJ
    545
    Many people use air pillows, but some do not. The "real" reason for the pillow is to provide a cushion for ice to expand against if your pool freezes. The thought being if you did not have one, the ice would instead push against your pool walls.
    However, many people also find the pillows useful for keeping water off the cover. It makes it easier to drain when there is a "moat" effect. Some people pump off their covers (I used to before mine started leaking) - it lets the leaves blow off. Others let water get on top - it helps with wind. You just want to keep any water at or below the normal water level in the pool when it is full.
    There is not much you can do about snow, except look at it. As long as your cover is resting on the water underneath, it should be fine. If you have it stretched like a drum, the weight of the snow is going to rip it. Even in a bad winter, I tend to find a few days of a warm spell where there is meltwater in the cover. I just pump that off.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    For snow, there is a device called a roof rake that works great for pool covers. Make sure you get one with little wheels so you don't drag too far down and hurt the cover.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
