Thread: Winter cover issue
    Jul 2015
    Fremont OH
    42
    Winter cover issue
    This is my first winter with my 18x33 above ground pool. Had a great summer with it, and everything went well.
    It's rather windy where I live, and I'm out in the country with little to block the wind. I've had more than one person tell me not to even bother with a cover in the winter time, but I'm stubborn, and not good at taking advice sometimes.
    I closed it this past weekend, and put the winter cover on it. The winter cover is tightened by a cable, and that part worked well. It also came with plastic clips, and those are worthless. I've put them on twice, and they've popped off twice. I also bought a roll of the industrial plastic wrap, and that lasted one day before it blew off. The cover is permeable to water, and any water I put on top of the cover either soaks through, or blows away.
    Anytime the wind kicks up, the cover billows up like the parachute in gym class. At this rate, there's no way this cover makes it to April/May when I can open the pool again.
    Suggestions? Let the cover stay as long as possible, and give up when it's done? We don't have a ton of trees, but there are enough to make a mess if there is no cover.
    Aug 2011
    Augusta, Kansas
    88
    Re: Winter cover issue
    We too have the "jiffy pop popcorn" cover. Fortunately our pool is surrounded by rail road ties. So we screwed some heavy duty eye hooks into the ties and then looped rope through it making a grid and pulled it pretty tight. It's windy in Kansas and our pool is fully exposed. The grid helped contain the top and it didn't fly off like it did in prior years. You do have to put something between the rope and the edge of the pool if you want to reuse the cover next year as the rope did a number to the edges of the cover where it had rubbed all winter. We use a cheapo tarp from Harbor Freight so we had planned on tossing it anyway. The pool was clean when we uncovered it unlike the prior uncovered years where the months of dirt from our dirt road were in the pool.
    Diane
    15,000 salty gallons - 24' x 12' x 52" Intex Ultra Frame Pool
    Intex Sand Filter, Pump, SWG - TF-100 and speed stir
    Jul 2013
    Long Island, NY
    532
    Gallons: 5000 Gallons
    Pool: 15' Saltwater 5000
    Filter: Pentair 1 HP Optiflow Pump w/ Clean & Clear 75Sq Ft Cartridge Filter
    SWG: Intex CS8110
