Thread: Polaris 360 Questions
    wjaneala's Avatar
    May 2015
    Cullman, AL
    163
    Recently, my Polaris 360 has started doing this thing where it always ends up in the same corner of the pool and gets stuck. Yesterday I found it lying on its side in the shallow end. Any ideas on what might be causing this? I'm really hoping it's an easy fix, as I don't really want to buy a new cleaner right now.
    Wendy
    1980s 20x40 in-ground beast, 36K gallons, 4' - 8', vinyl liner, Sand Dollar sand filter, two skimmers, bottom drain, three returns
    TF-100 Test Kit
    H-12 1/2 Mike's Avatar
    Apr 2014
    Highland Village, TX
    75
    Re: Polaris 360 Questions
    Check your hoses. Every time mine acted like that we had a bad hose.
    16,400 gallon
    Cartridge Filter
    IG
    Intelli-Flo @ 2000rpm
    wjaneala's Avatar
    May 2015
    Cullman, AL
    163
    Quote Originally Posted by H-12 1/2 Mike View Post
    was your problem leaks or blockage?
    Wendy
    TF-100 Test Kit
    Apr 2014
    75
    It is possibly a split hose. But I would also check the screen filter where the hose connects to the pool.
    16,400 gallon
    Cartridge Filter
    IG
    Qwaxalot's Avatar
    Jun 2012
    439
    Check the head float. They often leak & fill with water.
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
