Thread: Newbie
    Oct 2010
    SWF - Fort Meyers
    47
    Newbie
    I have a quick question. I will have an install in Florida. Did any of you tamp soil before rebar? Did you tamp soil before and after pavers?
    Happy
    Roman Style IG 14X28, Gunite Pool and Screen Cage
    11600 gallons, 3.5 ft - 6.0 ft SWG TF100 Kit:)
    Spa with spill over, tanning ledge, swim bench
    Finish TBD, along with equipment and paver's
    Water trucked in were on well system in Florida:)
    Jun 2015
    Ottawa/Ontario
    336
    Re: Newbie
    You should always tamp disturbed soil
    68,000litre, IG vinyl, LorentzPS 600 Solar Pump & 1/2 HP Tristar, Sandfilter, Aquarite T-15 SWG
    20000 gallon, IG, SWG, Sand Filter, Hayward 1/2HP + Lorentz direct solsr PV pump
    philboyj's Avatar
    Jul 2015
    Houston TX
    326
    Re: Newbie
    The book says to tamp....but I have not seen anyone tamp before rebar - in Texas atleast. Whether it is for pool or driveway concrete.
    For pavers they always tamp the stone base using a hand tamper or a mechanical vibrator that looks like a lawn mower. The sand on top of the stones is not tamped as throughly as the stone base.
    The theory is that the heavy weight of the liquidish gunite will self Tampa required. Make sure they have adequate spacers at the bottom so that rebar is not lying on excavated bottom.
    Look for dig videos online and you can find out more.
    Geometric pool with all Pentair equipment. Raised spa - 18" with Artic Lagoon 1" glass tiles. 3HP VS Pump, 2 skimmers, 6 returns, IC40 Salt system, Easy Touch 8 with LED color light in pool and spa. 1200 sqft of Marble White Pavers decking in Versailles pattern. Tiling and coping almost completed, Indigo Blue Prism Matrix plaster. Pool Build Thread: Houston (Katy) Pool Build - Started April 2016
    Oct 2010
    SWF - Fort Meyers
    47
    Re: Newbie
    Thank you so much
