Thread: Regular pool maintenance
    Oct 2015
    THE WOODLANDS, tx
    65
    Hi all,
    Now that my pool is starting to get blue and the end is in sight, I am wondering about what I can expect when I am in maintenance mode.
    What needs to be done daily and/or weekly?
    Once SLAM is over, my FC will be over 25. Do I just wait until it gets to 7 or 8? Do we test everyday?
    I will keep pool going through the winter. Is winter routine different than summer routine?
    Please advise.
    Thanks!
    ~20,000 gallons, IG white plaster, Cartridge filter (make unknown), Filter Pump (Jandy Stealth Model # SHPM2.0), Probably over 10 years old, Spa, non-functional SWG (bad sensor), Taylor K-2600
    Jun 2014
    15,093
    Re: Regular pool maintenance
    Here are a couple good TFP pages to refer to:
    Pool School - Routine Pump/Filter Maintenance
    After the SLAM, the FC will drop on its own to your recommended (target) rate. Test FC everyday.
    Hope this helps. Great to hear your water is changing for the better.
    Oct 2015
    THE WOODLANDS, tx
    65
    Thanks for the links. I knew there should be something like that around, but I couldn't find it.
