Results 1 to 8 of 8
Thread: CYA stable or going down?
    Jul 2014
    Europe / The Netherlands
    95
    Triggered by a remark of chemgeek in post Foam that isn't?
    "By the way, don't forget to use Dichlor one day each month to help maintain the CYA level. You might test for the CYA level to be sure it's not too low. Chlorine slowly oxidizes CYA in hot tubs at the rate of roughly 5 ppm per month."
    I was wondering if the sticky "How do I use Chlorine in my Spa (or pool)?" would need a remark about degrading CYA?
    Until now i was under the assumption that CYA would last the water renuwal periode but now i'm wondering. If i understand it correctly than CYA would go lower in the period of time. So starting at 30 would mean about 25 at the end of the month.
    A wise man would say: why not now meassure CYA, and he is so right. BUT in holland the summer is over so it would be very hard to get the optimal sun conditions to do a good CYA measurement
    So perhaps next best thing (to keep cover allright) would be to add an amount of stabilizer each month to compensate for CYA loss.
    For my spa i guess about 0.3oz (9 gram) of stabilizer (478gallon/FC 4/PH7.5/TA50/CH150/Borate50/temp102)
    Or do i miss something?
    regards,
    edwin
    Arctic Spa Klondike Legend SE
    AG / Filter Cardtrige 50m2/ TFP / borates / TF100
    478 gallon @ 99.5-103.1 F Depending on season
    Ozonator disconnected
    Jan 2014
    Buckeye AZ
    807
    Re: CYA stable or going down?
    you could possibly order the 50 PPM CYA reference liquid. Then put together whatever artificial, repeatable light arrangement within your house so that you are reading 50 with the reference vial. Then you can use that same lighting going forward with confidence.
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    Sep 2013
    Charleston, SC
    537
    He is in The Netherlands and can't order from TFTestkits unless he has someone get it for him or makes a trip over here. Once your pool water temp reaches below 60 F or 15.5 C, the FC demand will drop and will continue to do as the water temp drops. I hope this helps.
    5900 G Fiberglass IG pool (circa 1990), SWG Hayward Aqua Rite GoldLine (2013), IntelliFlo Variable Speed Pump (2013), Hayward Pro Sand Filter (circa 1990), Well water (no iron or other metals fortunately), test with Taylor K2006C, Charleston, SC
    Jul 2014
    95
    Will the reference liquid also work for CYA of 30?
    Could take it with me next time I'm in the states.
    Sep 2013
    Charleston, SC
    537
    The reference liquid is a test to make sure you can accurately measure CYA using the TF 100 or Taylor K2006 test kit. If you read the reference test at 50, you are doing the test accurately. If not, you need to change something in your test until you accurately read 50 eg. light, distance, mixing etc.
    Mar 2007
    San Rafael, CA USA
    12,082
    Yes, the sticky should refer to dosing with Dichlor about one day per month (about 6 ppm FC worth). While testing for CYA would be ideal, just adding Dichlor one day per month should be OK since the degradation rate is fairly slow.
    Jul 2014
    95
    not sure which dichlor i need. For CYA add's i use the Pool Stabilizer from melpool. So i guess i'm somewher in the ball park if i add 0.3oz (9 gram) each month until the bright sun return's.
    Mar 2007
    San Rafael, CA USA
    12,082
    Sure, you can use Pool Stabilizer if you want. You don't need to use Dichlor. You want to add around 5 ppm CYA per month though after a couple of months you can test the CYA to see if you are indeed losing around 5 ppm per month. So yes, 9 grams (0.32 ounces weight) in 478 gallons would be 5 ppm CYA.
