Results 1 to 10 of 10
Thread: Pool Cleaner Advice: repair or change cleaner?
    I currently have a Kreepy that needs a new base and some new hose. Each replacement hose piece is 10.00, or 100 for all 40 ft, plus the 50.00 for the "base", plus shipping. Total about 180.00.
    I also have an Aquabot, without the remote, that continually sucks up the electric cord.
    My pool is a 16 x 32 foot inground vinyl, without a dedicated cleaning line. I have two lines (returns?). I purchased a new 1.0HP Sta-Rite dynaglass pump last summer.
    So, do I repair the Kreepy or invest in a different type of cleaner? I can't use a booster cleaner without the dedicated line, can I?
    19,000 IG Pacific Blue plaster,raised spa with spillover,rock waterfall, Jandy 2.5 HP pump,Pentair sand filter,Paramount in floor cleaning system, Jandy Aquapure SWG, Aqualink remote
    Mar 2009
    Glendora, California
    169
    Re: Pool Cleaner Advice: repair or change cleaner?
    I feel the response to repair or replace would vary on who you ask and should probably be up to you and your checkbook. I repair my Kreepy Krauly as needed and I get my parts from the Internet, usually from the big auction site. The prices were much lower than the pool store and the parts worked fine.
    How old is your Kreepy? Do the other parts look OK or need replacing soon as well? I paid about that for my Kreepy from the Internet.
    18k Inground Plaster pool / TriStar Variable Speed Pump and Controller
    48sq ft Hayward DE filter/ Swim pure Plus 40k cell / Kreepy Krauly
    Solaxx Ph-Tek
    The unit is actually only 1 year old. I was very surprised to have this issue so soon, as the last Kreepy held up much longer.
    What big auction site are you referring to?
    30,395
    Welcome to the forum. All the robot cords I have seen float up and out of the way of the cleaner. Does your cord not float?
    Your post seems to indicate you have dismissed the aquabot but, depending on the model, it should have quite a bit more cleaning power and be better suited to your pool size.
    no-mas's Avatar
    Jun 2008
    FL
    405
    Quote Originally Posted by pmccaul1
    Probably ebay. I buy parts for all kinds of things there - it is frequently the first place I'll check.
    18k gal inground, everbrite finish, 505 sq ft; 1.5 hp two speed whisperflow; rheem 5100ti 100k btu heat pump; 3 sheer descent falls; DE filter; swg (cell out and using trichlor for now)
    Well, I haven't actually dismissed the Aquabot, but it is very annoying that I can't leave it alone at all. Every time I walk in the house, it sucks up the cord. The cord does float, but when the bot travels around, it always manages to grab the cord. Every time! I work a lot of hours, and long days, so I want to have a cleaner work while I am gone so that I can swim when I get home...
    30,395
    I would make a call to Aquabot support. Something is wrong with your cleaner. Others here on the forum really like aquabots and have good success (I don't have one). Again, I don't know what model you have but most are pretty powerful cleaners.
    Mar 2009
    169
    Yes ebay is the place where I get my parts.
    EDIT
    Do you leave your Kreepy and hose in when you shock the pool? It's recommended that you take it out when shocking.
    Solaxx Ph-Tek
    Cherie's Avatar
    Jul 2008
    Wylie, Texas
    506
    We just bought a used, very old Aquabot Turbo for dirt cheap and it works great, with a couple exceptions. It doesn't cover the whole pool, and well, actually that's the only complaint we have. The little booger kept trying to eat it's cord. So we sliced a couple of pool noodles and put on the cord and that keeps the cord toward the middle of the pool. It did try to swallow a noodle, but couldn't get it, so it crawled over it instead and almost crawled right out of the pool. But that's only happened once and we feel comfortable about leaving it alone now.
    Too bad the older models don't have the option of keeping it strictly on the pool floor, like the newer model does!
    32x16 buried Doughboy, 4' shallow - 7' deep
    Pentair Dynamo 1 hp, 2-speed - Pentair 150# SD40 w/zeolite (75#)
    One skimmer/two returns/Aquabot Turbo T2
    Jul 2008
    Pittsburgh, PA
    118
    Aquabots do tend to eat their cords. They sell a part that looks like a tiny black football that you clip on. This is supposed to stop that. I havent talked to enough customers to see if it is working.
    Matthew
    Involved in the pool and spa industry
    Pittsburgh, PA
