Thread: Been away...question on FC
    ITR's Avatar
    Nov 2014
    Clermont, FL
    320
    Hi, all. I'm back again...it's been a while since posting and am enjoying catching up.
    Since this is my first year with a pool, I am learning a lot and it is balancing out nicely, but I have the following question:
    On 10/4, my FC was 13.5. It is now 10/14 and it has only drifted down to 7 over the last ten days (6.5ppm loss or about .65ppm loss per day). The temperature has definitely cooled to the mid to low 80s from the summer of low 90s every day. CYA is 40. The incredibly slow decline is surprising to me given during the heat of the summer is dropped a couple of ppm each day. Is this normal?
    I know you guys are going to ask for the full test results, so I am attaching it via a graphic (since copy and paste doesn't seem to work too well for formatting).
    15' x 29' 10,300 gal w/ spa, IG-Plaster (Stonescapes Tropics Blue), 2spd WhisperFlo pump (1.5hp WFDS-26), Pentair Clean and Clear CC200 cartridge filter, Pentair MasterTemp 300BTU heater, Clear o3, RS-8 iAqualink
    Jan 2014
    Buckeye AZ
    807
    Re: Been away...question on FC
    And you still have the Ozonator running?
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    ITR's Avatar
    Nov 2014
    Clermont, FL
    320
    Yes...hasn't been removed yet. And the Chlorinator has been off too. I am stumped...but maybe this is normal for "fall" in Florida?
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Is the pool inside a screen enclosure that may be blocking some of the UV?
    Support the site
    ITR's Avatar
    Nov 2014
    Clermont, FL
    320
    I definitely have a screen enclosure and it has been fairly cloudy as well. I won't be too concerned then. Thanks!
