Thread: PH Level and Muriatic Acid
    johnallen21's Avatar
    Jul 2015
    Odessa, Florida
    2
    Hello All, a quick question about my PH levels. I've been caring for my pool for a little over 2 months now and I'm noticing an odd trend. My PH levels seem to love to be at an 8.0 with an alkalinity of 80. I follow pool math and add Muriatic acid weekly to drive it down to the prescribed 7.5-7.8 range but after a week (with no rain) it's back up to an 8.0. I do have a small waterfall on my hot tub (hot tub is pool temp), my thought is the small bit of aeration caused by the hot tub is causing the PH to trend upwards. Does that make sense?
    here are numbers from today's testing:
    FC: 6.5
    pH: 8.0
    TA: 80
    CH: 300
    CYA: 75
    John
    13,000 gal, in ground gunite /// Pentair Diatomaceous earth pool filter/// SWG/// K-2006C FAS-​DPD kit
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: PH Level and Muriatic Acid
    It does make sense. What I would do is allow your TA to drop to 70 and see if your pH rise slows. Even let it go to 60 and see how that goes. I think you'll find you'll be using less muriatic acid with slower pH rise if you allow the TA to drop a little more. The only thing you'll have to worry about is your CSI being too negative at that lower TA level. Check it out with Pool Math link up above.
    Welcome to TFP!
    Isolated Spa - 345 Gallons
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    going from 7.5 to 8.0 over a week isn't very bad at all. lower it to 7.2 and see how long it takes to get to 7.8. lowering it to 7.2 will help lower your TA some as well, but honestly your rise seems very maneageable.
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    Jan 2012
    'burbs of Augusta, Georgia
    7,338
    You mention you've been caring for the pool for two months- is this a new pool? If so it certainly should still be curing and the pH rise is expected during this time. Just keep monitoring it and bringing it down with the MA. You can also drop your TA a bit as suggested above and see if that helps.
    Also-remember that anything providing aeration such as a fountain or spill over will also naturally raise the pH. Try curbing that (if applicable) and seeing if that helps.
    Jul 2015
    Odessa, Florida
    2
    Thanks everyone, much appreciated!
