Thread: Mounting pool automation box on side of house??
    May 2015
    Fullerton, CA
    636
    Was thinking is it better to mount directly to the stucco or put a couple 4x4 in the ground and mount to them next to the equipment pad? I am just thinking about this as we plan to paint the house in the spring. Painting around all these wires and the box might not be best?
    33x19, 3'4"-5'6", 7ft spa, baja reef, 14'x9', 18" deep, 10,668 Gal. Quartzite coping, Stonescape Tropics Blue mini-pebble, abalone & glass beads. Jandy Equip.(JXi heater, 2.7HPVS pump, PLC1400 SWG, CV580 filter, Aqualink, LEDs)
    TF-100, Doheny Discovery robot.
    22,553
    Re: Mounting pool automation box on side of house??
    You've kinda already answered your own question. If you're already thinking that it'll be a problem, it's probably better to build a little rain shed to put it under slightly away from the house wall.
    May 2015
    Fullerton, CA
    636
    Good point, I did not think about the rain, good point! or at least paint that wall before the equipment goes in.
