Results 1 to 7 of 7
Thread: Anyone know why 3 drain pipe connections in deep end?
    Jaimslaw's Avatar
    Jun 2015
    San Diego, CA
    300
    In the deep end, I have three separate 2" pipe ends that are covered by standard drain covers. When the pool was emptied for a replaster, the drain covers were removed. Two of the drain covers were for the typical set of two 2" pvc pipe drain lines. But a nearby third one was capped off (inside threaded cap with the square male socket on top). Anyone know what that is? I would think that if it was or meant to be bypassed by the original PB, it would have been gunnited or plastered over.
    My replaster PB thought it might be a pipe that runs straight down for some hydrostatic, water table reasons. I was thinking its a backup drain line, tho I see no evidence of a capped pipe sticking up out of the ground at my equipment pad area.
    Anyway, just curious to know why its there and/or what function it might serve.
    Cheers.
    Pool: 13k gal. in-ground; Stonescape Mini Pebble - Tropics Blue; Connected Spa - dual spill-over; Aqua Rite T-15 SWCG; AquaLogic PS-4 Automation; Sta-Rite DE Filter; Sta-Rite Max-e-Therm 400k BTU pool heater; Intellifo 2-VST Pump; Stenner 45mp2(25psi/10gpd) acid injection; Bulbwizard color LED pool lights; Poolvergnuegen 2 wheel side suction cleaner; FAFCO rooftop solar. TF-100 w/ speed stir.
    Jun 2012
    western NY
    1,559
    Re: Anyone know why 3 drain pipe connections in deep end?
    My guess is it is to relieve any ground water that may want to cause the pool to float. When the pool is empty, it should be removed. This will allow any ground water pressure to equalize and not try to push up on the pool. Remember, and empty pool is more of a boat than it is a pool.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Jan 2012
    'burbs of Augusta, Georgia
    7,296
    I concur with Danpik..it sounds like a hydrostatic valve, a very important element to use when the pool is emptied for repair. Make sure to open it up if you ever drain the pool to avoid floating the pool out of the ground.
    Jaimslaw's Avatar
    Jun 2015
    San Diego, CA
    300
    I wish I had opened it when the pool was empty for a couple of weeks recently just to see if any moisture or water would be seen. My property is located in a canyon at the bottom of a slope, so maybe that had something to do with having this installed. I've always been aware of the pool float possibility when empty, which has kept me from ever even thinking about emptying it during or shortly after the rainy season (which here is SoCal, is something of a distant memory).
    Jun 2015
    Wildomar, California
    423
    If it is a hydrostatic valve, which I'm sure it is, was it checked to see if its workable? If your pool is an area of a high water table, it should be functionable. Pools can pop out of the ground even when full. I know, I've seen it when I used to work in the LA area. You're in SD? Big El Nino this year, lots of ground water. Something to think about.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    I seem to agree with the others that is to relieve hydro-static pressure, but from your description it does not appear to be the more common automatic valve, but something you manually open when the pool is empty. Something to remember if you should need to drain the pool again.
    Support the site
    Jaimslaw's Avatar
    Jun 2015
    San Diego, CA
    300
    I suspect it was required by the city because of the pools close proximity to an underground French drain system (large 18" dia.) That the developer placed at the toe of a steep slope that comes down to my property line and is only a few feet from my pool. I'm going to look at the original plans and general spec plan notes to see if it shows up in either.
    13 year pool and several emptying events with no signs of lifting. As to Any future emptying I will be opening that upto be safe.
