Thread: Air bubbles from return while pump is off
    Oct 2015
    Safety Harbor, FL
    3
    We recently purchased a house with an in ground pool (our first pool). This site has helped us to get the water cleared up and the chemical levels back in range.
    Now that things seem fairly stable, we are starting to look into an apparent water leak. The bucket test shows we are losing an inch or so over a couple days. On a few occasions we have seen air bubbles coming from the return on the shallow end of the pool while the pump is off. Is this a clear indicator of a leak in that return line? What should our next steps be? Should we take the time to do the bucket test with the pump on and with it off?
    -Greg
    14000 Gal In ground, Cartridge filter (PFAB80), 1HP Pump (EUSQ1102 / Sta-rite P2R), Solar heater
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Air bubbles from return while pump is off
    Welcome to TFP! Congrats on the new pool!
    Sounds like it could be leaking when the pump is running and under pressure and sucking air when the pump is off.
