Results 1 to 11 of 11
Thread: Removing Pool Pump from "Hard Plumbed" setup
    Oct 2015
    Hollywood, MD
    4
    I'm new to these forums so any help is greatly appreciated. First time closing my pool by myself and I'd like to disconnect my DE filter and my pump and store it inside for the winter. The problem I have is that the pump was "hard plumbed" without any disconnects. I'm thinking about cutting the 2" pvc near the pool pump, store it, and use the 2" flexible PVC couplings, available at hardware stores, to reassemble in the spring.
    Something like this available from Lowes? http://www.lowes.com/pd_23462-34146-...=2%22+coupling
    Do you see anything wrong with my approach? Thanks for your advice!
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Removing Pool Pump from "Hard Plumbed" setup
    I'm not sure what size PVC is running from your equipment pad but you should install a proper union rather than a leaky hose fitting like that. This is what you need if it's 1.5" PVC: http://www.lowes.com/pd_188223-69305...t_price|1&pl=1 Should have one on the inlet and outlet side of the pump a few inches away from the couplings to the pump.
    I leave my pump outside all winter, fully drained and blown out with plugs removed, but have unions installed should I need to service or replace the pump. My sand filter also stays out all winter, drained, plug open.
    Welcome to TFP!
    Isolated Spa - 345 Gallons
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Support the site
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    What kind of pump do you have? Most pumps will have 1.5" or 2" STRAIGHT threads and thus take a union also with STRAIGHT threads (most ideal situation). A union pack like this one, with an outer o-ring (indicating it is STRAIGHT threaded and not tapered), is ideal.
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
    Oct 2015
    Hollywood, MD
    4
    Thanks for your advice guys!!... to answer some of the questions, my piping is 2" and I have a Pentair variable speed pool pump but it appears that the pool installer permanently glued a 2" to 1.5" reducer to the pump inlet/outlet. Per your suggestions, I'll use a PVC union instead... just have to figure out if I have enough room to splice it in
    Oct 2015
    Hollywood, MD
    4
    Quote Originally Posted by Goearr View Post
    FYI, my layout...
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Cut the pipe where you've indicated and unscrew the fittings threaded into the pump body and add the unions like what I linked to and you'll be all set.
    You'll likely need a coupler and some extra 2" pipe and another elbow. Or at least that is how I would do it. I can almost guarantee you that your PB installed male adapters into your pump and those will be typical tapered threads. In fact, most folks do it this way despite the fact that the pump threads are straight. You can make a seal and they will thread fine but in some cases one can get a leak. It is better to use straight threaded unions (and not pipe nipples or male adapters) in this case.
    You can, of course, cut the pipe and put in regular old PVC (slip fit) unions if you want...I just wouldn't do it that way.
    ----Chris----
    wjr75's Avatar
    Jun 2013
    IL
    836
    Sounds like a lot of work. We just have everything winterized and in the spring after a few feet of snow melts fire it back up
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Jan 2014
    Buckeye AZ
    807
    considering all the crazy 45/90/45 back the other way type PVC runs I've seen posted on here lately, that's a pretty clean setup. Who knows what it looks like underground though...
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    Oct 2015
    Hollywood, MD
    4
    Quote Originally Posted by Agent99 View Post
    That would definitely be the "proper" way to do it... as in using something like #6 from the third post, an outside threaded union. I'll have to see what the PB actually did once I cut the line and try to thread the coupling out of the pump. I believe the pump thread is 1.5" so I'll have to find a 1.5" outside threaded union with a 2" non-threaded pvc adapter on the other end. If it becomes too much, I'll just splice a 2" union (#7 in post 3) close to the pump inlet/outlet. Thanks again...
    Quote Originally Posted by BuckeyeChris View Post
    Thank you... I was there the entire time so I know that the pipes go down about 6' to a 90 which are then connected to flexible 2" pvc lines. That's pretty much the only thing they did a "decent" job on... the pool is another story!
