Thread: Starting Filter/Circulation with water 1 ft under the returns
    Jul 2009
    Massachusetts
    188
    Hi, I am trying to shock my pool with the water level about 1 foot under the returns on the deep end of the pool. Is that OK? I can turn on my water flow to intake from the main drain only and return back through the inground cleaners in the deep end. Is that OK? I want to shock the water before I refill and close for the winter.
    My whole story is here:
    http://www.troublefreepool.com/threa...179#post937179
    and
    Here:http://www.troublefreepool.com/threa...something-else
    btw, sorry for the multiple posts. I took the day off from work to deal with this so really anxious to get it done today. worried about leaving the pool this empty. Thanks
    25,000 gallon gunite pool with waterfall (built 2000 - owner as of 2009), Aerotemp / Aquacal heat pump AT12000-A, Hayward DE4800 Filter, AOS UST1202 Motor, Hydro-King T104P201 Timer, Meyco pool cover, Pentair Model 320 Auto Chlorine Feeder. Located in Massachusetts.
    Apr 2010
    Central NJ
    227
    Re: Starting Filter/Circulation with water 1 ft under the returns
    If it was me, I would close it with the water the way it is and deal with it early in the spring when the water temp hits 60. if you want to clear it, then I would be worried about the splash when pouring the chlorine. This is what I would do, but do at your own risk. Pour the chlorine without splashing and us a broom to help circulate it throughout, of course all of this with the pump running.
    23K gallon, IG, Vinyl, Hayward DE-3600 Filter, Raypak 406A Heater, Hayward 1.5HP SP2610X15 pump aka AO Smith UST1152, TF-100 Test Kit
