Results 1 to 9 of 9
Thread: Abandoned return?
    Sep 2015
    Orlando, FL
    22
    Abandoned return?
    I've got this in my pool wall... I'm assuming it is a return that got clogged? It was left that way after a replaster right before I moved in. I have no leaks, and there is no water movement from that pipe.
    Two questions:
    - Is it worth getting a cheap USB camera and seeing what's in that pipe?
    - I've got 3 other returns (green checks). The only circulation problems I seem to have are stuff not moving to the skimmer from the deep end, and stuff gathering on the bottom about a foot from the main drain. Should I have 4 returns in a pool this size, or is 3 enough?
    8200g IG, Diamond Brite Plaster, Hayward Cartridge Filter, Pentair Pump, TF-100, Rainbow 320 Inline Tab Chlorinator [not used]
    Jan 2012
    'burbs of Augusta, Georgia
    7,252
    Re: Abandoned return?
    That looks like my Polaris line. Are you sure there isn't a valve someplace turned off to this return?
    Most likely a vacuum line or a pressure cleaner line.
    Support the site
    Sep 2015
    Orlando, FL
    22
    Interesting. I only have a single jandy valve, between the skimmer and main drain. But I DO have a stub of a pipe sticking up near those pipes that is capped. I wonder if that was originally a vacuum line.
    Qwaxalot's Avatar
    Jun 2012
    439
    Quote Originally Posted by dmorriso View Post
    Sent from my SCH-I435 using Tapatalk
    Yep, it's intended for a pressure side cleaner (could also be used as a vacuum port). This was a fairly common practice not long ago.
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    I had one of those too at my old place....it ended at a disconnected pipe in the pump room.
    Dolphin E10 Cleaning Robot.
    Sep 2015
    Orlando, FL
    22
    Quote Originally Posted by borjis View Post
    Did you do anything with it, or just leave well enough alone?
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,179
    Well, right now with no plug it is an area of little to no circulation. This could become a breeding location for algae. I see it you have two choices:
    1. Get a threaded plug for about $3 at lowes and plug the pool end of the pipe.
    2. Tie that pipe in with the other returns back at the equipment pad and put an eye on the threaded end. Probably less than $25 in parts.
    Support the site
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    Just left it alone.
    The pipe in the pump room it came from was much narrower than the return lines, so I didn't think
    of making it into another return jet.
