Thread: Jandy 700 giving 170's
    I happened to have a spare back board and I still get the errors. The error is displayed right after power own. I checked all transformer points and they are good. The cable that connects back to front boards is in bad shape, any way to test on the front board end?
    Jun 2011
    Long Beach, CA
    2,787
    Re: Jandy 700 giving 170's
    Follow the troubleshooting guide in this, http://www.nuccibros.com/sec_0934drR...20Workbook.pdf.
    Mar 2015
    New Orleans, LA
    81
    99% sure you need a new sensor. I am a Jandy warranty center and almost always code 170 is a bad sensor. If you look at it it probably has a rust spot on the contact. Make sure you get the new style.
    The sensor is new, just inspected in in the beginning of the summer. I'll take a look though I would not agree because the fault is immediate, the board does not even have time to power up to check a sensor voltage?
    Ping, thx but that is not the right board?
    Jun 2011
    Long Beach, CA
    2,787
    Try this link for the older models, https://www.inyopools.com/manuals/16...rror-codes.pdf.
    It says to remove the sensor from the board, does the 170 error go away? Yes, then replace the sensor, No replace the front board.
    Quote Originally Posted by ping View Post
    That helped and ConradM is correct, bad sensor.
