Thread: Don't know the exact size of pool
    Sep 2015
    Phoenix, az
    15
    Hi everyone,
    I am almost near my closing date to purchase my house with a pool. However I have tried asking the seller the size of the pool. He said the home was a previous rental and doesn't know. Is there any way to calculate the size of the pool and how much water it holds?
    Thanks
    Jun 2014
    15,103
    Re: Don't know the exact size of pool
    I'm assuming this is an inground pool correct? This page may help get you going: http://www.poolandspachemicals.co.uk/volcalc.htm. Once you get a basic number, then you can use the Poolmath calculator to really dial it in close. For example, let's say you estimate the pool to be 15,700 gallons, but every time you use the calculator to add bleach the FC result is higher. Then you know your initial pol size estimate was probably too small, so you increase the gallons on the calculator until the chemical result matches.
    In addition, you'll see some pool calculation tools on that Poolmath calculator as well. That's a couple ways to get a good idea of your pool size.
    Sep 2015
    Phoenix, az
    15
    Thanks, when we move in we will do the pool math. I am totally new to all of this.
    Yes it is an in ground pool.
