Results 1 to 16 of 16
Thread: Tips for removing top of Hayward Chlorinator?
    Butterfly's Avatar
    South Carolina
    10,045
    The top of our Hayward auto chlorinator is stuck. Really stuck. Won't budge!
    Any tips on how to get this thing off without breaking it?
    You're done SLAMing when:
    Aug 2007
    Eastern Canada
    54
    Re: Tips for removing top of Hayward Chlorinator?
    Quote Originally Posted by Butterfly
    Have you tried a strap wrench with a rubber strap?
    Boa Constrictor is the model I have.
    (http://www.amazon.com/gp/product/B0011EACZC)
    I have a Rainbow 320 chlorinator, so I am not sure how the Hayward comes apart, but from pictures, it appears that a strap wrench would do the job.
    18X36' 25000 gal Jacuzzi vinyl Inground Pool (1985) with resin sidewalls, newer Jacuzzi 1 hp two-speed pump and sand filter. Raypak propane heater, Rainbow 320 chlorinator (mostly use bleach).
    Softtub 220 portable hot tub.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    A strap wrench would be my first try. Lowe's carries one with a rubber strap that is handy on all pool fittings.You might also want to pour some hot water over the lid too.
    Butterfly's Avatar
    South Carolina
    10,045
    Thanks derekm & JohnT,
    A strap wrench is the only tool DH does NOT have in his arsenal
    Got hot water, though! If it doesn't work, guess we'll head to Lowe's!
    Thanks, again
    Guest
    Dearest Butterfly,
    My suggestion would be to cut it out and replace it with a Pentair Rainbow Lifeguard chlorinator if you are dead set on having one!
    IMHO, Hayward chlorinators should be replaced at the first reason to do so! Sometimes an individual from a very good family just goes bad....such is the case here!
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by waterbear
    Dearest Butterfly,
    Dearest waterbear,
    I am not dead set on having one, but seeing that it came with the house, we DO have one, and use it at our leisure Of course, we are aware of the consequences (pros and cons).
    Also, being on retirement income, we do not have the $$ to run out and buy another brand, just because it might be better.
    If it should need to be replaced, it will probably be done by the next owner.
    Also, all the equipment appears to be original which is 1992, therefore, I'd say that it has had a good long life and been a good combination
    Now, if we can get the top off, we can try it again
    Mar 2007
    Coastalish 'down easter'
    4,160
    Joyce, why didn't you just PM me That lid WILL come off!
    Are you remembering to push in the tab on the influent side while trying to turn it?
    Do you have a jigsaw so that you could make a handle with notches to match the 'crenallation' of the lid? Do you have a pair of channel locks large enough to grip the crenallations? Do you have a 3/4" wrench so that you can pop the tab in the center of the lid and unscrew the bolt and then attempt to get the top of the lid off and then use a screwdriver to pry up the sealing plate?
    If you go the 'brute force' way, be sure to brace your feet against the pipes going in and out of it (right foot to the right of the effluent pipe and left foot to the influent pipe) so you don't break the pipes
    If you need more help or replacement parts (you'll probably have to replace the o-ring (CL 200 - K), shoot me a PM and I can probably get you one fairly inexpensive (for some strange reason, I've got a bunch of pool parts at my house ).
    {edited to correct the part # -- it's been a long winter if I can't give correct Hayward part #s )
    Luv& Luk
    -Ted
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by waste
    ...influent side....what's that...geez
    Do you have a jigsaw so that you could make a handle with notches to match the 'crenallation' of the lid? Do you have a pair of channel locks large enough to grip the crenallations? Do you have a 3/4" wrench so that you can pop the tab in the center of the lid and unscrew the bolt and then attempt to get the top of the lid off and then use a screwdriver to pry up the sealing plate? Ted, you are obviously directing this stuff to my DH (jigsaw, channel locks, 'crenallation' , bolt, screwdriver, pry, sealing plate, .... I will print this out for him!
    If you go the 'brute force' way,You are definitely talking to Johnny here be sure to brace your feet against the pipes going in and out of it (right foot to the right of the effluent pipe and left foot to the influent pipe) so you don't break the pipes Rut Row, gotta watch DH on this one.....
    If you need more help or replacement parts (you'll probably have to replace the o-ring (SP 200 - K), shoot me a PM and I can probably get you one fairly inexpensive (for some strange reason, I've got a bunch of pool parts at my house ).
    Ted, fair warning, you should probably look out for a PM heading your way
    Mar 2007
    4,160
    Joyce, if I weren't ready for it... I wouldn't have suggested/asked for it 8)
    I'd have thought that you KNOW you can ask these things of me
    You give so much to the folks here that the LEAST I can do is help you (on those rare occasions you need it) with your pool
    Thanks for the well wishes w/ my mom - SHE says I ought help you as best I can too
    NEVER! be reluctant to PM me on anything!! - that's what friends are for (musical note emoticon )
    Luv& Luk
    -Ted
    Butterfly's Avatar
    South Carolina
    10,045
    Thanks Ted!
    How sweet of your mom! Sounds like she is doing great, too! Yeah!
    We're supposed to have wonderful weather today so we'll get out there and play with that lid!
    I'll keep you posted.
    Aug 2007
    Eastern Canada
    54
    Thanks Ted!
    Just wondering what did the trick...
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by derekm
    Sorry, I really meant to give an update before now
    Waste (a/k/a Ted) gave DH the confidence that he could remove the top w/o killing the thing, so.....
    Using the tools he has on hand....
    DH said he used some WD40 & let it set for a while. Then he used a big pipe wrench, verticle position, w/jaws fitting into the notches. Then bumped, bumped along with a little 'brute force'.
    When I got home that day it was done
    Why are they still selling this. Mine is new been on and off 2 times before it started acting up..got a plastic strap wrench and gonna try it but this needs to be taken off the market imo
    Jun 2015
    NY
    54
    Quote Originally Posted by Steve S View Post
    I don't know, they really are a bad design. I'm going to switch to a pentair chlorinator or forgo any chlorination device and add straight pipe.
    So far i have 2 slip joint pliers on opposite ends that I jerk to get loose. I got so frustrated I used rubberbands and zip ties to keep one of the pliers permanently on lol. It is possibly the ugliest solution but is a rather easy job. You can buy a plastic part that costs $20 that does the same thing. I've rotated it the wrong direction on more than one occasion...Lesson learned I always read the open and close direction marking. This method take a total of 2 minutes to set up and use. Before the rubberband I was trying for like 10-15 minutes without a large channel lock.
    The suggestion to cut a piece of wood with a jigsaw seems pretty good. I imagine cutting two 2' pieces at the center, using the same cutouts and slipping them on the lid and rotating would give you great leverage. Like someone said don't crack your pipes or unions.
    14K gallons vinyl IG pool, L shaped diving, hayward s-200 sand filter/side mounted multiport, hayward cl200 chlorinator, Pentair Intelliflo VSP, 1.5" cemented plumbing, Dolphin diagnostic. 3 Returns, 2 skimmers, 1 MD, 1 polaris port.
    I took the rubber pads off a quick clamp and straddled the lid with the clamp placing the ends in the notches. Removing the rubber pads allowed the ends to seat in the notches. The clamp worked as a handle which provided plenty of leverage. Good luck!
    DIY Fiberglass Pool under construction
    30,400
    This thread is over 6 years old and I doubt it will get any response.
