Thread: Main drain, skimmer, and return plumbing
    May 2015
    Fullerton, CA
    635
    I have read here it's better to plumb the skimmer and main drain separately to the equipment pad, anyone know why this is recommended?
    Returns, how many? Where should they be placed? I have read the wall returns should be about 18" below the water surface. How many on bottom? One of the PB wants to put 4 returns in, 3 on the walls one heat return on the bottom. The other builder puts 3 heat returns on the bottom?
    Confused, is there a better design?
    33x19, 3'4"-5'6", 7ft spa, baja reef, 14'x9', 18" deep, 10,668 Gal. Quartzite coping, Stonescape Tropics Blue mini-pebble, abalone & glass beads. Jandy Equip.(JXi heater, 2.7HPVS pump, PLC1400 SWG, CV580 filter, Aqualink, LEDs)
    TF-100, Doheny Discovery robot.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,805
    Re: Main drain, skimmer, and return plumbing
    If the skimmer and main drain are plumbed separately them you can choose to pull from one, the other or both so more flexibility for various circumstances you might encounter during the maintenance of your pool. All plumbing them together does is save the PB a few dollars, but very few.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    May 2015
    Fullerton, CA
    635
    Thanks, is this a real world issue? Being that I have never owed a pool I don't know the real world pros and cons. No PB I have spoken to runs separate lines for drain and skimmer, one will do it for a pretty big price upgrade.
    Any thoughts on the deep water heat returns? 1 vs 3? On the bottom? How many total? Pool is in SOCA, 3.5-5 ft deep.
    Was told too many returns will lower pressure and my spa spill over will not work well?
    Thank you
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,805
    We spec'd the separate runs but it was also our PB's SOP. So at least one does.
