Thread: Starting SLAM soon. Some questions
    Oct 2015
    THE WOODLANDS, tx
    65
    Happy saturday everyone!
    So I am gearing up for a SLAM. Pool is currently being drained to bring CYA down. I t will probably take most of today. Then I will refill tomorrow.
    Does this schedule look ok?
    Monday - refilll. Test at the end of refill. Add MA or soda ash to balance pH. Run pump all night.
    Tuesday - test in the morning and start SLAMing
    Once slamming starts, should I test every 2-3 hours?
    Anything else to keep an eye on?
    Thanks in advance!
    ~20,000 gallons, IG white plaster, Cartridge filter (make unknown), Filter Pump (Jandy Stealth Model # SHPM2.0), Probably over 10 years old, Spa, non-functional SWG (bad sensor), Taylor K-2600
    Jan 2012
    'burbs of Augusta, Georgia
    7,367
    Re: Starting SLAM soon. Some questions
    Actually once you start a SLAM process the more you can test the faster the SLAM goes. Hourly is ideal, but many folks can't commit the time to do hourly. Just do as often as possible so you're maintaining that SLAM level of FC but no less than 2-3x a day.
    You can start the SLAM as soon as your pool is filled, make sure the SWG is off and keep the PoolMath link handy on your desktop for quick access to guide you in your liquid chlorine additions.
    Check your filters often to avoid them getting clogged up with schmutz.
    Oct 2015
    THE WOODLANDS, tx
    65
    OK thanks
