Results 1 to 7 of 7
Thread: Any seals that are part of the pump motor itself?
    Feb 2014
    dfw tx
    67
    So I have a 12yr old challenger pump when it works it works as a champ lately its been eating seals once a year but its no big deal since its toward the end of the summer when I mow the grass short and some of the clippings end up in the pool impeller ( i still can't figure out how)
    Anyway this last week it started leaking water so i figure its the seal. Replace the seal ps100 and it works for about half a minute and then it starts shooting out water again. Take it apart and make sure seal still seated perfect and it is. Back together and its still leaking like crazy. Pull out my plumbers usb camera and the water is coming out behind the last seal right against the housing of the pump. mine doesn't have any seal when i removed it and its never had it. The housing is already rusting so just making sure i can't do anything to save this pump setup vs replacing it.
    currently its 1hp is 1.5hp a ok stepup? wont hurt anything?
    16k gallons
    IG "roman style" plaster
    Pentair CCP420 Clean and Clear Plus Pool and Spa Cartridge Filter, 150-GPM
    1hp pump
    Built in 2000
    Jun 2015
    Wildomar, California
    423
    Re: Any seals that are part of the pump motor itself?
    Replace pump seal, check. Did you replace the seal plate gasket? You should always replace it when you replace the seal.
    poolkid's Avatar
    Mar 2012
    Mesa, AZ
    77
    The Challenger pump uses a PS200.
    Here's the cross reference guide at US Seal.
    APSP Certified Building Professional
    APSP Certified Service Professional
    NSPF Certified Pool Operator
    Feb 2014
    dfw tx
    67
    hmmm weird i wonder what the difference is, i've changed it twice with a ps100 and both times its held water for 6-8 months.
    Digging thru the pump i've only encountered the pump seal. Im not sure where the plate seal gasket is but all the other ones i've changed last year and they were good.
    Sorry just looked it up i did order and install the ps200 shaft seal.
    16k gallons
    1hp pump
    Built in 2000
    Feb 2014
    dfw tx
    67
    Changed out the entire pump motor and still got the same problem. Put in old seal vs new seal same problem.
    Changed impeller bolt same problem
    Changed impeller itself same problem.
    Took apart and seals are still in place everything seems normal I can't figure this out. Crappy pics from plumbers camera:
    Any help?
    16k gallons
    1hp pump
    Built in 2000
    Jun 2015
    423
    The Challenger has an O-ring that fits in a slot in the large,round, seal plate. Its circumference is about 8-9 inches. Have you changed it?
    Feb 2014
    dfw tx
    67
    i've changed 26,13,12, and the seal set ps200 #3.
    I can't find any place for a seal on the seal plate?
    16k gallons
    1hp pump
    Built in 2000
