Results 1 to 12 of 12
Thread: Test reagents
    Sep 2015
    Corpus Christi, Texas
    37
    Test reagents
    Can anyone post the actual chemical content of the reagents and indicators used in the various
    tests recommended here?
    In addition the chemical reactions going on in the tests would also be very useful.
    Apologies if this is already posted somewhere. If so, a link or references would be appreciated.
    Thanks
    Texaspops
    In ground, inherited, 30 yr old, concrete with plaster. 14,100 gals, triangular, 3.5 ft uniform depth. Pool Valet bottom cleaning system. Autochlorinator using 3" tablets (now stopped using!). Spa with overflow into main pool (1500 gals). Jacuzzi Magnum pump.
    Lots of southern live oak trees!
    aussieta's Avatar
    Jan 2014
    Langwarrin, Victoria, Australia
    490
    Re: Test reagents
    Welcome to Taylor Technologies
    this may help,
    dont forget - between r and number eg r-0870
    SWG inground peanut shaped eco-bright concrete pool
    50,000 litres 13,000 gallons
    Lincoln Salt Chlorinator, 25 gram cell Sand Filter with glass media
    Taylor K2006-C test kit, Taylor K-1766 salt test, Dolphin M500 pool cleaner
    are you taking care of your pool or is the poolshop taking care of you
    Sep 2015
    37
    Re: Test reagents
    Quote Originally Posted by aussieta View Post
    this may help,
    Thank you.
    Some are helpful, some are not. e.g. for R-0008, alkalinity reagent is listed as 95-99% dihydrogen oxide (!),
    and 0.1-5% components below reportable levels!.
    R-0004 also has 90-99% dihydrogen oxide and 0.1-5% trade secret, and 0.1-5% components below reportable levels.
    Are they really selling us water, giving it a fancy name, and calling it a reagent? What are these other components?
    Most of the others contain 90% water.
    Also these do not include the chemistry behind the tests.
    Texaspops
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,197
    Re: Test reagents
    What you are asking for is why Taylor stays in business. Are you trying to duplicate the tests?
    I can see many of the tests having water as filler to make the test work properly at reasonable levels.
    Support the site
    Sep 2015
    37
    Re: Test reagents
    Quote Originally Posted by tim5055 View Post
    No, just wanting to understand what is going on. Too much trouble to duplicate!
    Not to worry, I will still buy the kits. I expect they will stay in business.
    I am sure that details these tests can be found in most texts on water analysis and even used in HS or freshman
    college chemistry lab classes. They are hardly on the level of nuclear secrets.
    Water at 90-99% is hardly "filler"! It is the major component.
    I was also amused (and I guess a little galled) by listing the chemical name as deionized water and then the common name as dihydrogen oxide!
    If anything it should be the other way round.
    Especially as the instructions for first-aid say use water (not dihydrogen oxide).
    Texaspops
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Test reagents
    See this post for chemical names and a little about what they do and this post for some rough shelf-life. Most tests are done via standard methods though each vendor has some proprietary chemicals to improve preservation of dyes or help prevent interferences. As for how various chlorine tests work, you can read Current Technology of Chlorine Analysis for Water and Wastewater.
    Sep 2015
    37
    Re: Test reagents
    Quote Originally Posted by chem geek View Post
    Thanks once again!
    I had already seen the paper, and I appreciate the links to old posts asking the same questions and the responses which are useful.
    Interesting that others also remark about the some reagents being listed as 99% water and the rest some unknown
    ingredients and the general evasiveness of some MSD Sheets! It's not just me then!
    I would surmise that for some of the vials of reagent, the vial costs more than what it contains!
    (And not just the Taylor ones).
    Texaspops
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    Re: Test reagents
    Quote Originally Posted by Texaspops View Post
    Thanks once again!
    this can be said regarding many products, have you bought a can of Coke lately?
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    Sep 2015
    37
    Re: Test reagents
    Quote Originally Posted by EVChargeGuy View Post
    Of course I am well aware of that fact. "Whataboutery" does not change what we are discussing.
    The answer to your Coke question is actually no, but for reasons not relating to value for money.
    There are many alternative beverages that I can buy, which may or may not provide better value, but not so many
    choices for good swimming-pool-water testing kits. And the price/ounce of reagent is at least 10x that of Coke and approaches
    the price of a decent Scotch (also mainly dihydrogen oxide, but 40% hydroxyethane plus tiny amounts of other substances)!
    Texaspops
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,258
    Re: Test reagents
    On a side note, a can of "Coke" is really bad for you, owning a TF-100 Test Kit is extremely healthy, and having a Trouble Free Pool is "Priceless".
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    JoyfulNoise's Avatar
    May 2015
    13,254
    Re: Test reagents
    Perhaps the better way to look at it is this - you are paying for the intellectual capital that was/is expended on making these products Just because most of these dyes and indicators have been known for decades (in some cases, since the beginning of last century) doesn't make them worth less. Taylor has expended a lot of intellectual capital and ingenuity in bringing to market products that are quick and easy to use as well as stable and accurate. They may be formulating chemicals that are >95% water but it is that last 5% or so that took an enormous amount of effort to develop. They deserve to be remunerated for their hard work and willingness to take the risks to bring an excellent product to market.....and let's face it, if Taylor can't make a little bit of profit off their hard work, then their products will no longer be sold and you, I and everyone else on TFP will be in deep doodoo as a result
    Matt
    30,432
    Re: Test reagents
    Texaspops,
    I guess I am trying to figure out your point. Are you saying that Pool water testing is a big rip-off?
    Then don't test. Taylor, LaMotte, Hach, Blue Devil all offer reagents and testing methods but none of them force you to buy anything....ever
    Pharmaceutical companies sometimes make terrific profits from a drug they discover but you are NEVER forced to buy it.
    In each case, you make a choice whether or not the value returned to you is worth it.
    Let's get this thread to a sharper focus or it will seem like you are simply complaining about something over which we really have little control........other than exercising our rights to purchase it or not.
